Headlights on When Garaging~Cause Trouble?
Maybe silly question here.  I park in a garage at home.  It takes me just long enough to park that the headlights come on in place of the DRLs (garage is dark) before I am stopped and shut the truck off.  With the HID bulbs in my LT is this going to cause a problem with the bulbs or ballasts?  It isn't like I am doing this multiple times per day or something, but it catches my eye that the headlights click on, initially looking very bright against the wall, and then dimming down after a second.  Not familiar with the lifespan or number of cycles these things made to handle.
thanks
It’s not really good for the ballasts but what you could do is as you are about to pull in just shut the DRLs off till you are parked in the garage. Your headlights won’t kick on then
How do you turn off DRL’s?
Turn the knob that controls headlights to the left until it springs back.
Sent from my SAMSUNG-SM-N920A using Tapatalk
That doesn’t work in Canada
It's because in Canada you need to have on the DRLs correct. If you have 16+ you can turn on the headlights before you enter your garage.
I sort of figured as much.  Guess maybe I can try to wear the switch out instead of the ballasts.
Thanks
if it is daylight out, I reach up and turn the headlight switch to the left and turn the daytime running lights off every time. There is a thread where someone details taking the headlight switch out and removing the spring that makes the headlight switch spring to auto.
thanks
I would not worry or alter anything.  I could count on one hand the number of times I've had to touch my headlight switch in the past 10 years.  The electrics are designed to last and I doubt you are anywhere close to meeting or exceeding the design expectations of these components.
I have the same situation with my '14. I've been running HIDs since late '15 and have only had problems with relays.
thanks
The HIDs in my 2007 Z4 are still going strong and it acts similarly every time I pull into the garage.  I wouldn't worry myself.
For non-canadian trucks you can just turn the headlight knob to the left of where it is on automatic and it will disable DRL. It will read a message on the DIC of automatic headlamps disable or something like that.
For Canadian trucks, try to turn the knob to the right just once to turn on the running lights. Your headlights should stay off in this mode (at least they do on mine and I have a 14 silverado with the halogen bulbs, not sure about the newer HID/LED lights) and then when you get out turn the knob back off.
I know in my old GMC Envoy there was a way to wire up the DRL to a relay so it would keep the DRL's disabled every time you turned the truck on. This probably won't work since the DRL is controlling the led portion of your headlight and then when it gets dark enough you are turning on the headlamps and parking lights as well.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
