After some research I was unable to locate a thread on a 2016+ Sierra front conversion, so figured I would put one together for anyone interested! I know this conversion isn't for everyone due to resale value, costs, what the VIN says, and so fourth. Personally I love the iridium metallic and the options I have, so coming to terms with locating a 16 Iridium AT didn't make sense.  I began with the headlights a few months back due to the lack of light output on the stock 14-15 lights, after a bit of time the 16+ trucks began to grow on me more and more.
Let me start by saying..finding used 16-18 parts is challenging, the bumper being the hardest in my opinion. After a few months of sourcing parts, I was able to acquire everything at significant price differences over new. Minus the 16-18 headlights, the conversion cost me right around $1,800 said and done. Still having all the original 15 parts, I should be able to recoup a bit of that back. As for the 16+ Silverado conversion, more is required to be changed then the Sierra. From doing the swap I found that I needed less then I originally thought. As of right now I don't have working fogs, but that shouldn't be an issue. Unfortunately, the harness is on national back order.
Parts Required for Bumper Conversion (see pics below)
-Complete Bumper Assy (including brackets, fog lights, lower valance, harness)
-Upper Top Pad
-Sight Shield
-New Grille (Chrome, All Terrain, Denali..)
*Green boxes are required purchase parts
*Yellow boxes are optional purchase or modification of old part
*Red boxes are parts not needed
*You will have to locate 4 retainers for the grille, these are already pre drilled, As for everything else, it goes together like a breeze!
(16+ Headlight Conversion) please see post below:
(Bumper Assy) I didn't use either of the yellow items in the photo below, I trimmed the old side retainers down roughly 3mm
to accommodate new top pad:
(Wheel Moldings) As for the wheel moldings, I trimmed just shy of 1.5" on them and sanded down to save on costs:
IMG_0177.thumb.JPG.db0dca7c5f8f5f09bf4e3833d32cef13.JPGIMG_1134.thumb.JPG.12d68a245c184954173f9f003c6a3764.JPG
Edited by 15SierraAT
  • Like 7
This is a very detailed list of requirements. Nice work!
  • 3 months later...
WOW awesome job dude! What if i only want the grill and headlights of the 2018 on my 2014? Do I need to change to bumper too ao the grill can fit? Or it isn’t necessary? Thanks in advance!
The headlights will work on a 14-15 body style with a correct harness no problem. The link on that thread is up above. As for the grill, that will require the entire swap above as the 16-18 grill is larger than the older model.
  • 3 months later...
Where can I get the headlights harness ?
Most likely@pgamboa can make you one, but I could be wrong
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
Any chance you still have your old bumper lying around ? I'd be interested in taking it off your hands.
Thanks.
On 12/29/2018 at 12:20 PM, midwestdenaliguy said:
I have a 16 so don't need to do this, but wanted to say this is an amazing write up. Guys like you make jobs like this easy. Nice work!
Thanks for the support!
Thanks.
Sorry I don’t, sold it shortly after the swap
6 minutes ago, Cdubb8704 said:
Don't think he checks his inbox often. Waiting for a couple responses myself.
Responded to pm
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
