Towing 29,000 lbs???
Pretty general question but what's everybody's thoughts on a 16 crew cab dmax dully towing close to 30,000 lbs when loaded. I know it isn't legal but dot doesn't really enforce where I'm from as far as trucks limits they'll just make sure you've got a cdl. Do you all think the truck is capable of safety towing that kind of weight or should I make the in wanted jump to a ford that's rated for the weight?
Jake
Sent from my G8142 using Tapatalk
towing the weight is one thing but stopping it is another , i dont think gm or ford have good enough braking systems for that kind of weight
The new 17 and up f350 is rated for 30k and the f450 like 34k but I don't necessarily want to get on the powerstroke wagon unless I have to.
18 wheelers are rated 80 and more , i dont know how far or where you are towing but if it is in the mountains you better have perfect brakes on the truck and trailer i have driven 18 wheelers for 40 years and have been lucky enough to only crap my pants a few times.
In the 90s early 2000s I towed 24K combo legally. I used the same vacuum over hydraulic braking on one trailer, with dual axles. The trucks used, 91 3/4 ton Ran diesel, 94 Ram diesel one ton, 96 Ram V-10, 98 3/4 ton power stroke, 2002 one ton Ram. I average 50K miles per year pulling to job sights and demos. The trucks job is to pull and assist in stopping. The trailers job to stop its load. My trucks brake wear was less when I was using my trailer.
So to hopefully help clear it up a bit about the truck and trailer. The dually will be a daily driver towing a 38 foot toy hauler for me and a seven horse trailer for my wife with a 15 foot living quarter on it also and will be very well maintained. As for the weight the only one I'm worried about is the horse trailer, loaded it will be close to 30k without the truck. The truck will be mostly driven around the Midwest so really no hillsto worry about.
I did look at a 18 wheeler but don't want to hassle with getting pestered about being commercial or not and for my farming the dually makes more sense to me at least for the simple fact that I can drive it everyday easily. I would obviously get air bags for the back end towing any of our three trailers. The truck will be hooked up probably 3 days a week.
I just got get why GM rates their trucks so much lower than the competitors. Like do you guys really think that the gm offerings really are less capable?
My experience was, having the load center to the trailer the best tires you can buy and most importantly the trailer brakes. My trucks usually only dropped an inch loaded. Just enough to not to loose traction taking off.
If you look around at the people pulling flatbeds, hotshot oil field services, commercial freight & wedge trailers hauling cars you will see they are plated at or near 36,000 lbs. I know some in that segment have moved on to class 4/5 trucks, but a lot were one tons(from all 3 mfg's). That said, moving that much weight very often will rag a truck out.
You’re also comparing (at least I think you are) an f450 and a GM 3500. Are these comparable? Do what you’re gonna do, just stay in the midwest so I don’t become a victim of your negligence. 30k is about 23.3% over capacity for the 3500 dually.
If you have to go power stroke so be it. But don’t put others at risk for brand maintenance.
Sounds like an experience hauler, the name fits.
There's a reason they have weight limits on trucks, safety. If you want to safely tow that much weight get a truck that's rated for it. If not, it's all on you my friend. Be safe.
Ya, think?  Crazy in 3/4 tons can't believe they gloat those numbers!
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
