preferred gear ratio
Hi everyone I am looking at ordering a new truck with the 6.2l and I was wondering what your thoughts where on gear ratios.The way the brochure reads I could get the 3.23 or the 3.42 ratio. I would be rarely pulling a trailer but where I live it seems like you are always bucking a wind of at least a 30 mph. I know with the older trucks I have had with 4 speed transmissions the lower gear ratio not only give better performance but with the windy conditions  better fuel mileage so I thought I would see what you might recommend with these new transmissions.
Here's the deal with the 6.2:  the 3.23 gears are for the NON max-tow trucks  and 3.42's are only available on the max-tow. I have a 15 max-tow with the 6.2 and 3.42's and they're just fine with me. You also get the added benefit of the tow mirrors and a bigger radiator--well worth it in my opinion.
I drive a cc 4wd std bed with a 4.3 V6 and a 3.42.  Strong winds and occasional towing aren't  a problem.  I imagine a 6.2 with a 3.23 would have significantly more power at the rear wheels than my truck so you'll be fine with either combination.  It is a case of how much unused power you want in reserve.
Most of the gearing attributes are accomplished with the new 8L90e and it's 8 transmission gears. With more forward gears, there is less emphasis on the final drive ratio. You would never notice the 3.23 compared to a 3.43 except when loaded to Max GVW. The 3.42 might net you a tenth or two in the 1/4 if your a sport truck guy.
I’ve got a 6.2 in a High Country with the 3.23. I would go to the 3.42. If you are even remotely considering a taller tire then it becomes absolute. You’re not going to see a loss on the top end by going to slightly taller gears. My .02 cents.
Thank you everybody this forum is much more knowledgeable then the dealer I did not know that you need the max trailer pack to get the 3.42 gears since I would be getting the z71 pack and you cannot get the max trailer pack in that trim I guess 3.23 it is.
I specifically looked for a 6.2 max tow with 3.42. I immediately put larger tires on 32.7”. My speedo is 2 mph or 5% slow with larger tires. Truck still goes into v4 in town and on highway.  My gear ratio is prob closer to 3:23 now.
Point is if you are going to put larger tires on get the lowest gear ratio available.
i have the 5.3 8sp with the 3.42.. it digs through the gears ... ..good low end torque
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
