My truck also has an misaligned right rear door. My dealer said they would fix it. I walked the lot and 80% of the new trucks has a misaligned right rear door to some degree. 50% of all trucks had a misaligned that I, as a consumer, would laboe as unacceptable.  I will update after the dealer repairs it. I am thankful the dealer is trying their best. This is a manufacturing problem that they, or me, should be having to deal with.
I have a 2017 gmc and a 2018 Silverado, my Sierra is perfect and my Chevy is shitty.d6f17e56c4cc43d103d7704ae3cd7960.jpg
How the factories works to save time and money is they will let standards slip and go from 4mm to 8mm out if people don’t take their vehicles in and complain.
Any resolution to this? Have had my LT Crew for about 2 weeks and noticed the same gap on the right rear door at the bottom. All other doors sit better. Trying to figure out what the dealership would do to make it look flush.
No perfect resolution. Dealer adjusted the door so it is slightly better but any more adjustment and the door would be too far in at the top. Dealer showed me a bunch of new trucks on their lot that had the same issue so I gave up. Same thing with the tailgate not flush on the side. Almost every truck I looked at had this issue.
6 minutes ago, SilveradoGraceland said:
Going to go to dealer tomorrow and see what they suggest.
Keep us updated!
Went to two dealerships and spoke with their body shops. Both recommended that they can manually twist or bend on door to get it closer. One said it’s pretty common for them to do that. Not sure I’m willing to go that route. May just live with it since they said it won’t effect the interior of the cab (weather, wind, etc)
I wonder what the process consists of and if there are chances of damaging the door. I'd be worried.
Went to 3rd dealership body shop and they are going to put new bolts in rear door hinges. They said they have done this to several Silverados and Sierras and it makes it noticeably different. They even said they would paint them which is a nice gesture. Thoughts?
  • 4 months later...
What was the outcome? I’m going through this with my dealer, both rear doors not aligned also bed off to the drivers side.
I work at a paint and collision shop. Yes, Chevrolet has a lot of alignment issues straight from the factory. Especially with the rear doors at the bottom. If you think these have issues, you should see Ford body alignment issues. They are way worse. Brand new vehicles shouldn’t have these problems. That’s what happens when vehicles are assembled in Mexico. Poor quality control. For the Silverados, fixing that lower rear door requires a lot of twisting in the door. Almost to the point where you could cause damage to paint. When we come across the problem, the truck usually needs repaint in that area so we can really bang and twist on the door to get it almost perfect. My 2016 Silverado has alignment issues all over the place. I just drive it and enjoy the ride. Like the post above says: it’s a truck, not a Lexus. Don’t expect American made vehicles to be perfect. Cause they’re not American Made anymore.
Well, mine are good but I have "tweeked" several doors over the years...last one was a 2008 Avalanche. Had some wind noise from the drivers window area...lowered the window, open the door, put your knees on the door and GENTLY give a few tugs to the top of the window frame...test drive and repeat as required but it's worked every time. The trick is to not tug too hard the first few times and do it gradually. No more wind leak sounds. Have no idea how to fix the bottom of the door.
Edited by SS502
That's ridiculous.  I expected and got perfect panel alignments on my American built Silverado. For over $50k, I wouldn't except anything less.
On 4/30/2018 at 6:12 PM, TECH12 said:
I have that same gap on my rear door. The two rear doors do not shut easily. Everytime I close it without thinking about it the door doesn't shut completely. I took it to the dealership and they said that's how it's supposed to be. I'm going to another one
My friend had this issue on his 2018 Sierra. The cause for him was that he put one of those storage bins that are made to go under the back seat. With the seats down, they pushed on the bin a little which in turn flattened out the GM all weather mats causing the rubber to push out slightly making it a bit harder to shut. I think he ended up trimming the mats.
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
