On 5/4/2018 at 9:14 PM, Dub1796 said:
Ill take that trade lol, i prefer the one piece that my 2014 had. When u come up to Canada for the swap, bring me a set of 24" strada codas with you from cali haha
I would be interested in a trade for a sliding rear window.  I have 2020 LT solid rear window.  I am near Yellowstone NP..
Maybe someone in northern mountains?  Near zero virus cases here.
I don't know what the situation is for border crossing with Canada due to Covid-19 crap.  Anyone know?
Cheers,
YMMV
Edited by Mogur
Ok changed out from solid and now have a power slider. @pgamboa really helped me out. This guy knows the wiring of these trucks like the back of his hand.
So if someone wanted it shipped and paid for it, the solid is available to ship now as well. Packed in box ready to go. 188901e297641d7af1bee751ef18de5f.jpg
This is after the swap. She is a sexy one. If anyone wants to n ow where motor is this is where you place it. ac8f768714a7403124e97f748c3572c2.jpg
Nice!  I installed the GM power slider in my uplevel 2018 SLT.  It was pretty much plug n play.  Did you have to drill holes through the cab to mount the power slider motor?  I did not have the threaded studs in place.
That is strange that your truck did not com with that option.
Did you put the factory switch in the overhead console?
Yes, all factory.  I only had to add the fuse block on passenger side, along with the short console wire harness.  The harness going down to the driver fuse block and junction block had the needed trigger wires and power wire.  I think having the sunroof and noise cancellation gave me the needed harness.  Of course I bought the console trim panel and switch.  I have to give credit to Mike (mkwambold) for all the help and encouragement.
That means you have a down level SLT, not an up level one.  The base and premium packages didn't have the power sliding window.  Could only be had on the Premium Plus (or Denali, of course).
IDK???? 6.2 lt, Sunroof, heated and cooled seats, bose with console, 4x4, navigation, heated steering wheel.  The only thing it does not have is the driver safety package which I don't care for.  Happy with my new sliding rear window :)
Also front parking assist, LED headlamps, trailer brake controller (unless bought as a separate line item), spray in bed liner (again, unless bought as a separate line item).  I saw several packaged at dealers that were Premium units with several stand-alone options to like buckets and Bose to get it like the Premium Plus but the price ended up not being much less once optioned out that way.
Go Dawgs!  You're a long way from the Classic City...
Howdy, All...
I also want to install a slider in my 2017 Sierra. I wanted to ask those that have done this:
did you do yourself? I’m having issues finding a business that will do it.
what did you install? Factory or aftermarket?
did you have to remove the headliner?
Thanks for any tips,
~Freeman
Most shops shy away from installing something that was not originally installed from the factory.  Most people that have done this mod do all the work themselves with the exception of installing the window it self.  My glass shop did NOT want to install mine saying the truck was not set up for it.  When I pressed them on the matter, they said the whole rear seat and interior has to come out. and they did not want to get involved.  When I let them know that I had removed all that myself, they went ahead and did it for me. 60.00 to remove the old glass and 60.00 to install the new GM one.  If your truck has a sunroof it is mostly plug n' play; at least it was for me in my 2018 SLT sierra.
Just do what I did.  All you need is the right side fuse block for trucks with the power slider, a new upper console wire harness that is applicable to the slider and any other options you currently have, a new trim plate that will support the rear slider switch, the rear window and the power window motor.  You may, or may not have to, run three wires down to you brake controller junction block and driver's side fuse block.  These are the open and close signal and 12vlt power.  I did not have to do this as my truck had the correct harness, this was most likely because I have a sunroof and the noise cancellation options. Just make sure you have the back seats and garnish moldings off when you go to install the rear window.  Let me know if you need help with any thing else or part numbers.
No I used elevator studs and jb weld. After it dried it worked great
Yeah the military brought me out here and wife and kids have kept me here. Lol
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
