4 minutes ago, garagerog said:
Yeah, but that front clip has me scratching my head, Pontiac grill with what, Eldo fenders and hood? This reminds me of Johnny Cash's song "One piece at a time". Looks like the guy that assembled this got fired at GM for stealing before he finished the job and landed a gig at Airstream.
Tornado I think.
  • Replies 3.3k
Top Posters In This Topic
2 minutes ago, Donstar said:
When we first got married I would tell my wife half truths about modifying my vehicles. Dual exhaust gives you better fuel mileage as well as changing to 4 barrel carburetors. Her family wasn’t into performance vehicles. She didn’t have a clue. Exhaust rumbling even on mom’s Eldorado was common. I was really turning over cars early on. Finally car magazines started showing up. My wife started to appreciate what was going on. And I lost access to the checkbook and was put on an allowance. That slowed down the car flipping to where I actually had to come out ahead. She became an enthusiast and drove performance cars to this day.
I couldn't pass this up
make-america-athiest-again
  • Thanks 1
5 hours ago, diyer2 said:
That's a heck of a long hose! Wished they'd have longer hoses on some of these pumps.
I remember when they went to short ones. Made it harder to fill up my dual saddle tank Chevy 1/2 ton
Title of video should have been more like, "Man makes entry into Darwin Award contest"    Clearly he does it on purpose, guess he want to find out what would happen. Plus he's recording it.
A case of FAFO
Edited by txab
