  • Replies 3.3k
Top Posters In This Topic
2 hours ago, garagerog said:
 Yep, looks like the plastic surgeon got carried away with DOT 5 brake fluid, but hey maybe she has a high boiling point, measured wet of course!
I think the surgeon got carried away with the grease gun and those zerk fittings.
  • Haha 2
5 hours ago, txab said:
Now we know where our last vice president is working.
  • Haha 3
