  • Replies 3.3k
Top Posters In This Topic
Play that funky music
Fluid Liquid Ocean Wave
Edited by diyer2
  • Haha 4
10 minutes ago, diyer2 said:
KARNUT exclusive.
Automotive Wheel System Chopper Rolling Spoke Motorcycle
Don’t laugh. I was looking into turbocharging for the mini van. I wanted to out run my brothers Super Snake. I had to realize he finally out did me. Maybe nitro, nope
  • Haha 1
3 hours ago, customboss said:
Im
almost out
You keeping up with your muffler bearings maintenance? :)
  • Haha 2
A squirt of Amsoil MP like we used on
our M16’s makes it stop squeaking. 😱
