2 hours ago, starman8tdc said:
   Good info, thanks for posting.
   From what I have read, the direct injections systems are definitely superior to all the predecessors. I have been working on various cars for decades, but I have not had any issues come up with that particular fuel system.
   I will definitely study the system well before taking one apart.
It's funny you mention you haven't seen any issues yet, I haven't either. I ran into a code on a Hyundai a year ago and it pointed to the high pressure fuel pump, that's about it. Most of the complaints I hear about is the noise of the system.
I imagine most issues are still being handled by dealers because on some cars it's still relatively new. But Audi has been using it for years, haven't seen many issues except for worn followers on the cam. Come to think of it BMW was having some high pressure fuel pump problems with the 535...and some destroyed cams.
  • 7 months later...
I am having the same problem with my 2016 it started about 4 months ago with only 47k miles now; after replacing spark plugs, o2 sensors and going crazy... dealer told me I have a bad injector # 7 however the recommend to replace all 8 injectors and while we are at it replace the fuel lines at a "discounted" price of only $1800.  ( it stinks to be asked to pay that much for truck you are still making payments on)
The service adviser pulled all the lame excuses; he even told me I have been putting some bad gas in there, I told him that it was the same gas that goes into the rest of the cars in my household and none of the other cars have any issues. (a Ford and a Honda that are running like champs with more miles)
Gordon and Partners is a law firm that has a office in the same building where I work; they have filed class action law suet in the past against car makers before for problems such as this one... as son as get around to it I will let you all know if we have a case and see if you would like to participate.
Far more than the 535.  Anything with an N54 engine (which went in the 135, 1M, 335, Z4, X5 and perhaps others) all had HPFP issues to where BMW extended the factory warranty on them.  It is a guarantee that the early units will fail...though most have been replaced by now.  The latest revisions seem to be more durable.
Their DI injectors are also suspect and use the same injectors on a number of different engines.  They are up to Index 12 injectors now, with multiple part numbers per index, so there have been a ton of revisions due to how bad their injectors survive.
Fortunately, the GM injectors are very inexpensive compared to the BMW units...about 1/5th the price.  You can replace all 8 GM injectors for under $400.
  • 7 months later...
My 2018 Yukon was diagnosed by independent GM-certified shop to have entire bank of injectors to be out of spec. It rough idles, but no codes. Guess, what did GM say... dealer tested and rough idle is “within GM spec”. I am looking at the report prescribing them to replace bank of injectors... they are simply instructed but GM not to perform expensive repairs on injectors, and dismiss them by “spec”. Nobody has ever seen this spec... truck is 8 month old and 9000 miles...
  • 5 years later...
On 7/12/2018 at 7:29 PM, YJSONLY said:
They are soaking/ cleaning carbon off (no charge to me because I have authorized anything to be done!!) say that the 2 injectors was bad ( I wander if someone just messed up a gasket or seal and just say bad injector idk)
What does this catch can do? Or do you have a link that is informative? On my phone app is kinda hard to sift thru stuff
When discussing direct fuel injection, it's important to note that it uses a 60-volt system. Carbon buildup occurs on the back of the valves because fuel no longer sprays over them. To clean this carbon buildup, a crushed walnut cleaning system is effective, preventing the need for a complete teardown. BG Sea Foam will not clean this buildup.
Each gas injector has a code for high, low, and medium flow rates, and you need to ensure the same flow rate is maintained on each cylinder to avoid drivability issues, such as P0300 to P0308 and other codes. Sometimes, you might get lucky with aftermarket injectors, but it's crucial to match the code of the new injector with the one you remove to prevent issues.
    • 2011 GMC, 5.3, 183k miles. OK, ....I don't know, this may open a bucket of discussionworms. Ha. Here's the issue. I've been following GM's "mandate" to use Dexos 1 oil, 5w30 (Castrol). I'm thinking maybe I should consider a High Mileage oil due to 183k miles. Castrol and Mobil 1 both make HM but both do not display the Dexos 1 label. So....since I'm way past warranty does it hurt anything at all to change to the HM oil? Its not "Dexos 1" but I kinda doubt it will hurt a thing. I'd like some input especially if someone has done this. Thanks
    • It is a company truck. Not under warranty. Both companies I’m involved with usually buy trucks that are discounted when looking. Except what the owners drive. Being retired and minority owner. I don’t drive a company truck. If they have the new GM gas engine it would be in a service truck.
    • Update!   Had the dealer look at the issue. First tech says no problem?? I said there was no voltage on the brake terminal on the 7 pin connector! He said he did not know what pin I was talking about. So they bring out a seasoned tech and I explain to him. He attaches a VOM and has me push the brake, and sees no voltage!!    Tom, the seasoned guy says lets go back to my service bay and look closer. We discover thru his on line system that the controller is a "smart controller" as it needs to detect a trailer connected before the brake voltage is allowed to the 7 pin connector!!! He also showed me a GM bulletin stating some trailers with LED lights have such low resistance the controller wont recognize them!!! I was thinking WTF, but thanked him for bringing me back into the service bay and explaining this all to me. He also plugged in a trailer simulator and it showed the brake controller was indeed working.   After my dealership visit I hooked up to an older camper with standard 1157 lights and the truck did connect and the electric brakes worked great!    Not to sure what I have to do with the equipment trailer with LED lights, I cant tow it with no brakes.   Why did something so simple for many years have to get so complicated!
    • Do find out as that would be interesting if they have been using any L8T engines or for that matter have been running any of the Ford gas 7.3 to see how they have been panning out.    I assume your nephews engine replacement was on his dime as the regular warranty would have long past unless he had some form of extended warranty that covered such events. That shows though and may depend on the year of the build that failures are occurring with the valve train well beyond the warranty distance and more than likely so will others have that sneak up on them.
    • I realize this is an old post and its probably been talked about since then on this forum and I may have mentioned it myself but the Chev multi flex tailgate on the HD trucks are all aluminum so there is that one item that I am aware of on a current GM HD truck that is aluminum but if its the standard tailgate then its still a steel unit as far as I am aware to current 2026 model year.
