I need this for my truck now im gonna get a bracket and see what I need to do! I've ben looking for a bumper so I can have a winch but I think I may go this route.
Let me know. I build the brackets for this setup. I haven’t seen any setup with that Westin plate. But to me, it looks like just the plate. Still need the brackets.
2 hours ago, rcpd34 said:
I would be interested in a hidden mount for my 2500HD.
I have not built one for the 2500’s yet. I can get the measurements and do one from one of the dealers here. What year do you have?
It’s a 2017
Not going to lie, that is a very slick set up. I think its very cool packed away behind the front plate. Nice welds too, laying down dimes like a kid at the candy store.
Due to recent uptick in interest. I am posting the pricing on here. I have a 2-3 week build time per unit. This is just a hobby and I am more than happy to help anyone with getting their truck to the look they want it. I am in the process of designing and building the 2500/3500 series hidden which setup.
I use 1/4 inch steel. I can pre drill all the holes but we have found that the factory holes and frames can be off by as much as 1/4 inch. It is best for you to drill your own holes in the brackets and plates. This setup does require you to drill 2 holes in the frame of the truck. One on each side. And drill out the threads to the rear of the tow hook nuts. I provide all nuts, bolts, and washers in grade 8. The front factory tow hook nut and bolt will be reused. All bolts are 1/2 inch thread. I also provide the snap brackets and bolts for the front license plate cover if your state required it.
Plate, brackets, and fascia bracket: $450 includes shipping
Plate, brackets, and 2” receiver: $475. Includes shipping.
On 7/5/2018 at 2:57 PM, Will O'Daniel said:
That’s a good idea. It would work well with the fairlead lower on the facia. Unfortunately, I can’t lower the fairlead because of where I put the receiver. This can be fixed for future builds if anyone wants me to build one. Where my fairlead is now, the plate would stick above the metal bumper about an inch that way. Taking the lines from the bumper and the grill. I was also thinking of building a receiver insert that can hold my plate. But, then it hangs low....... (joke inserted here).... First world issues suck lol.
You have done a great build with that truck, she looks great. What motor do you have in there, the 5.3 or the 6.2?
It’s the 6.2. As far as mechanical. I have 4.11 gears, BTR stage 2 cam, full exhaust with custom headers, K&N intake, and a  Black Bear dyno tune. It’s still a work in progress, but I have several other builds I am working on as well.
That is such a nice clean look. I like it. How hard is it to set the winch to free spool since it is behind the bumper?
Depends on the winch you use. I have tried to design a lever to assist with free spool, but it doesn’t work with all winches and each one is different. I have upgraded to the Zion 12 for my winches and it has an electronic free spoil via a wireless remote.
ahh, cool. I was just curious about that. That's a nice function to have.
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 2,256 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
