3 minutes ago, Foghorn17 said:
I have a $60K Denali; my sons' have $22K Subaru Imprezas.  The backup cameras on the Subarus are about 1000% better for night, visual clarity, color, video quality, etc; there's absolutely no comparison.  No other truck brand camera experience, but this is one small thing GM should work on with their trucks.
My 2014 silverado camera was pretty good, could not really complain it wasn't perfect but it was WAY better than the 2018. I will have to talk to the dealer about this.
What I also noticed is the 2014 I had the camera lens was flat, this 2018 the camera lens is a bubble.
There’s a TSB on these that reprograms/adjusts the brightness of the screen I thought it was for 017s and thought if was fixed for 018s but maybe yours falls into this?
There’s several threads on here about it.
TSB #17-na-269 (backup camera brightness)
I'm going to ask my dealer about this on my next oil change!
And as always... Enjoy your ride!
Recently bought a 18 SLT and the backup camera sucks, bad.  It's way worse that my 16 which was way worse than my 14... Anyone else notice this?  Maybe if I hadn't had one before it wouldn't be a big deal but especially on the same model of truck, just different years.  I can't see at all when I'm getting really close to something and backing out of my garage is horrendous at night, it's so washed out I can't see anything.
I noticed this as well...what’s really weird about it is my dad had a 2017 Sierra and the camera sucked, I have a 2017 Silverado and the camera is crisp and perfect, then he traded the Sierra for a 2016 GMC Denali Yukon XL and the camera is worse than the Sierra... I guess you just gotta be lucky
It's the picture quality. GM is SD where others are HD. I can't speak for Lexus, never drove one, but the Ford cameras are better. So I would think Lexus def would be? Either way, GM has the worst picture quality of any auto camera I have used. I don't have the upgraded camera package tho, not sure if you do? Can't remember what it's even called, just know that if you have it, you can add cameras to the front and sides if you want. I would have added one to the front of my truck, if I wouldn't have had to buy the whole upgrade.
This is true!! I do have the camera upgrade so maybe that’s why. I also have a front camera too
Going to dealership tomorrow to have them look at the camera, and told them to change the oil while it's there. They only charge 50 bucks so why not. It has only 150 miles on it I usually wait until 500 or so but next friday we leave for a 900 mile round trip so I figured this work good.
  • 5 weeks later...
let us know if it fixes the camera problem.
i have a 18 Sierra SLT CC and the camera is ok during the day but at night is terrible, as if overexposed, way to bright and at times makes it difficult to back up. next oil change i will also mention this.
They looked at it they said there's nothing wrong with it. I told them to put it next to the 2014 I trade it in and do a comparison they would not do that. During the day it is okay but not as good as my old truck, at night it's pretty much worthless.trying to figure out how I can get ahold of general motors and bring this up because I'm assuming we are not the only ones.
  • Sad 1
Night time rain really SUCKS!!  It is a contrast issue with the rear camera-not the display screen. I hate to say it but we own a 16' Toyota Camry and in the display menu the contrast and color can be adjusted, oh yes, the Toyota rear cam even works beautifully  in the rain.  Factory setting on the Yota blazed the screen with glaring white color at night, adjusted the contrast now its perfectly clear in the darkest areas and the color is better than factory default too.  We should be able to go into the settings on the GM's and adjust the contrast- just like Toyota , I'm sure there are other brands with adjustable contrast/color as well.
Now how do we get GM to take notice and fix this?  I am speaking of a 2018 GMC SLT , and yes the cameras are progressively getting worse= cheaper for GM.   We have run GM trucks since 1965, and have noticed since the advent of OEM rear cameras they are getting crappier as each model year rolls out.
On 7/12/2018 at 10:57 AM, Klutch said:
Definitely have this issue too but mine is an 18 and the TSB doesn't seem to cover it. Anyone else with the night issue on a 18?
I have a 2017 Sierra and have the same problem! Does anyone know if there is a way to turn off the camera??? I wish there was a quick way to disable it quick when a person doesn’t need to use it? It’s so bright when I’m trying to use my mirrors it’s awfully distracting!
I own the 2018 Sierra.  I have to say the camera do suck.. Its glitches and the resolution is bad.  I don't know why people would argue otherwise unless they are working for GMC, even then why wouldn't you want to hear the truth so you can improve.
My 2018 is crap. Took it in and was given a list of the infotainment versions that have the problem and was shown that my truck has one of the listed versions (IO6) and that they couldn’t do anything about it. To be told that I am just unlucky and ended up with one of the bad versions is BS. I have talked with the service manager at the dealership and he is going to contact GMC. The backup camera is required safety equipment and just like many of you have said, it isn’t just poor quality it is useless and so bright at night that it makes it hard to use the mirrors. If the dealership doesn’t fix it I am going to file a complaint with the better business bureau. GMC is aware of the problem and can fix it. They just don’t want to pay for it.
They give you a TSB number about the issue?  About to schedule my first oil change and plan to get them to look at it then
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
    • Sounds like maybe it's announcing Navigation turns or Alerts (it mutes the music) ? When it mutes again, turn up the volume quickly and see if maybe the navigation volume is really low?
    • If you were a classic car you would be a retro ride😆 Thank goodness for modern medicine.
