I doubt as there has been some RCSB Trail Boss mules running some sand dunes.
I can confirm that the 6ft6in box is body tagged 03-43-53 so 03 = regular cab, 43 = crew cab 53 = double cab.
Regular cab is last to launch too, I assume due to the fact that Ft.Wayne is handling crew cab and double cab launch production.  Once Silao starts spitting out crew cab T1 trucks (they are still doing 2018 crew cab), the regular cab will ramp up at Ft.Wayne.
Given how K2 was, I'd expect WT and LT for sure, and we might get Custom, Custom TB, RST and LT TB.
Edited by newdude
God I hope you are right! Thanks
Well GM Canada just messaged me back saying that reg cabs will be with 8ft boxes only. They have been wrong before in there messages to me. I hope they are wrong again!
24 minutes ago, Likarok said:
On page one of your attached guild I see code 107 with a 6'6" option under the reg cab column. Am I reading it right?
Yeppers.
I can't wait to see the double cabs!  Anyone know when they are hitting the lots?  I've only seen those photos of the blue model from the car shows.
Sierra Elevation Edition Double Cab:
I swear that looks like a freaking Tundra!
I currently own a GMC, but the 2019 GMC would not be in my Garage! :sick:
Silverado looks so much better in the front, and tail lights.
These GMC tail lights remind me of the 2005-2012 Colorado/Canyon style.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
