On flat stretches of road down at sea level maybe.
Unloaded i see 13mpg. Pulling my 10klb tt i see 7mpg. All on e85, wondering if diesel mpg is better to warrant a trade. E85 1.89 diesel 3.20. It would be nice to have that torque tho lol
Sent from my SM-G935P using Tapatalk
Brclark82, everything is perfect. I had dealer install 7way in bed. All I have to do is pop the timbrens in.
Note: I have a nice Kryptonite cable lock that I can use to secure hitch inside of truck. Just one more thing the theif would have to undo. I hate making things easy for them
Thanks for all your insight. Anything else, let me know.....
I run timbrens in all my trucks.  Had them in my half tons too.  I tried both air lift, and Firestone air bags.  I hated that i needed to add air when loaded and take it out when not.  They leaked air when it got cold, and had to take air out when lifting truck on lift.  I just put timbrens in and forget about them.  They just work.  Air bags did help but more expensive and harder to deal with.  In the picture it is 12,000lbs total.  The truck sits nice.   not sure why it cut picture off, maybe its the way i took it on cell phone. I also haul my tractor in my dump trailer
Edited by sillywillie07
Sweet setup!  Come back and let us see the sweet rig when you get it all hooked up.
Maybe some real world weights too.  Costs $11 at a CAT scale if you never done it.  Super easy and it will give you front axle, rear axle, and trailer axles (one weight for all trailer axles) with one weigh.  You could do an empty weight before you pickup the trailer if you really wanna know what the pin weight/trailer weight is after you load it.
Edited by brclark82
I have a retrax pro lockable bed topper on mine so that helps against thieves when I don’t wanna remove it.
Also, don’t forget to re-torque that hitch after you put the weight of the trailer on it.
Haha.... already investigating a tonneau cover.
I'll get pics. But I really don't want to know about weight. Cause there's not much I'm going to do about it. Best I don't know.
On 9/17/2018 at 12:18 AM, Colossus said:
For the cost of adding a supercharger, you could upgrade to a diesel and save $$$ all around.
Whipple's run $6100. Don't think you can upgrade to a diesel for that amount of money.
But the supercharged 6.0 is going to use gas like a fiend.
Supercharger on e85 should yeild some nice numbers. Curious how much more gas would it eat up
No doubt. Whipple claims 200h/p. The torque would be nowhere close to the Duramax at 900ft lbs.
It's possible on straight flat runs, fuel efficiency could be equal to stock. It's just I know how it goes when you need to drop the hammer. Gulp gulp gulp. Haha.
I'll do more research. Maybe I'll give it a try next year. Gonna have to think about this one.
horsepower under the curve is all that matters.  torque numbers are only relevant to the extent that they tell you something about the shape of the curve, since the tq number is specified at a particular rpm (and therefore hp can be derived at the tq peak as well).
a 6.0 with 200 additional horses from a supercharger will smack a stock duramax around all day long ... until it breaks.
Years ago a lot of guys were putting the old 6.0 in place of the ls1 and force inductioning them cause they were bullit proof. If i see a gd deal around 5k ill jump. Tune is around 600.
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
