On 9/22/2018 at 6:46 PM, SierraHD17 said:
I dont own a carbed engine that isn't a race setup....sorry dont care about dailying old stuff like that or running it when its winter....  How this pertains to 2015 and newer HDs is kind of lost lol.  Even the last 2 carb setups I have are going efi... carbs are only good for people scared of technology or required by racing sanctions to use them.
That would be me, an old bastid scared of technology, still have the 71 Chevelle SS I've owned since new, the spread-bore carb and for that matter the points in distributor have served me and that car well, plan on keeping it that way, who knows, it may be the only car running after an EMP attack, lol. A lot of small engine manufacturers still use carbs, probably because the complexity, cost, and vibration issues make efi impractical. Sure the motorcycle manufacturers and outboard boat motor manufacturers have gone to efi, price out a new outboard motor, they're getting close to $100/hp, anyone out there willing to drop $60k or so on a 650 hp crate motor?
Edited by garagerog
spelling
The suspension looks like it’s handling it pretty well actually.  Not a ton of sag, pretty level actually.
You said it’s hurtin, is that referring to the engine being underpowered or just overall too heavy for the truck?
Brclark82, kinda just thoughts based on numbers. (Not exact) glad I threw those timbrens in there.
I'll get a feel for it Saturday & Sunday. And report back.
Brakes on both truck & trailer feel extremely good. 8.5 on gain. Seems to be working.
500+ miles today. Truck was flawless towing the flatlands of the Midwest. Only one issue....6.4mpg @ 65mph. No way possible to get any better.  Going to take a detour thru Tennessee. I think I'd be really pushing things going from Nashville to Chattanooga. Where the elevation changes drastically.
Edited by jt metal
Nice set up there Mr jt metal, that's a toy hauler back there on that trailer? If you don't mind, length and weight of that nice looking rolling base camp? I'd be willing to put up with that milage to be "there" with that. Best upgrade for fuel milage towing that trailer is to buy a diesel unfortunately.
I'm sorry. Been busy......
T
Yes hauler, yes. Trailer pushes the boundaries of the truck.
Trailer weight is 10,800 unloaded. Pin weight is appx. 2500lbs, yikes!
So with Harley and goodies. I'm close to adding 1800lbs.
I spent weeks trying to sort out trailers. They are a nightmare that you would never believe.
  • 1 month later...
Well, after plenty of researching and procrastinating, I purchased a Whipple Supercharger and started to install it late today, should have it complete by tomorrow, or Sunday. I am not in a hurry, just making sure that everything is installed correctly. I have a 2017 Chevy 2500hd High Country 6.0l that I am installing it in.
Interested to see how this all works out with the trucks programming. Also you should start a new thread about this I think it would get lots of attention.
Edited by Saskquatch
Definitely keep us posted!
I agree with Saskquatch, start a build thread, lots of people would like to hear about this.
Yes, please let us know your results. Who is doing your tuning?
Been debating this but havent found any kits. How is it going thus far
Sent from my SM-G935P using Tapatalk
  • 3 weeks later...
Sorry for the delay everyone, I will write up my install this weekend on another new thread.
Do you have a follow up? Hows the drivability towing and non towing?
Sent from my SM-G960U using Tapatalk
    DaleB
    DaleB
  • Who's Online   5 Members, 0 Anonymous, 1,380 Guests (See full list)
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
