Come on......where's the heavy hitters? Haha.
I'm shooting for 13,000lbs...... yikes!
Finally had the chance to pull a 13.5k 5rh wheel. On the flats she did great at 60mph. 7mpg. Once i hit the mountains, she was working. Since then i have changed my gears to 4:88. Next is headers and take to get tuned and ditch the blackbear tune.
Sent from my SM-G960U using Tapatalk
I just picked up my truck from the tuner yesterday, and I have to say, this thing rocks. The tune from Whipple (HP Tuner)was not good for this engine/computer, it is a MF (exact words) to tune. My tuner basically creates his own tune and does a large quantity of calibrations for Whipple, which he is sending mine to them to use. The install of the supercharger kit was fun, but would suggest having a hands on tune done. I created a new install post and will list the dyno and driving results in the next day or two.
How has she been running this year
Any specific reason to remove the Blackbear tune or just the new mods are more than the tune can do?
Its a generic tune which i dont think offerred any real boost besides trans improvement.  think a dyno tune would be beneficial with my next mod, headers.
Towed this a while back, needed to redo the drain field, about 12K pounds, trailer had surge brakes, towed it fine, 60 mph max. 50 mile round trip pull, no milage report.
Get that dyno tune and headers yet? [emoji51]
I was scrolling through performance trucks.net and came across a red 2500hd that had an lsa charger with the red zl1 lid.....I really want to start modding [emoji17]
Thing should run pretty good with a cam and long tubes. I’d imagine even with a good tune they should run awesome. Would be nice to make some reliable power in the range of the new 6.6 and 7.3 engines.
On 1/31/2021 at 3:45 PM, cmysstailights said:
Headers are not in-stock till end of feb.
Where are you getting headers from?  I
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
    • Forgot to mention that this started after changing the oil I use mobile 1 full syn with mobile one filter but I did add pro lube additive and was the first time doing so and is making me wonder just can't see why that would matter
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
