4 hours ago, Nascarnate326 said:
2019 Oakwood RST doing some work. Muddy mess here in Michigan, treeline coming down and being hauled away one baby bed load of wood at a time lol
...and this is why I'll never buy a truck without an 8 ft bed... 😉
23 hours ago, PureZ71 said:
Mt Rainier was peaking out this morning
Sharp , what leveling kit set up do you have … nice stance
Thank you. I went with Ready Lift 2' sst kit. I did only install the front part of it for now. I'll add the rear blocks whenever I get a trailer. Link here
Edited by PureZ71
It needs it now, it looks nose high both visually and when just using the cursor to measure. Did you adjust your headlights down? These new LED's are hella bright when I come up on these new Sierra's and Silverado's.
I will say this makes me go back and for with going the long bed route next time around. Midsize trucks I would have for sure gone long bed with the crew cab, but the full size it is a toss up. Still have a couple years until I decide. Is there a long bed pics thread somewhere? That would be nice to see, a place where all the different CCLB's can be seen from stock to leveled to lifted.
Tyler
Tyler
Nah, its currently perfectly leveled. Measured from floor to fender front and back. I think the ground in that photo was slopped. Yeah I had the dealer install it, align and lower the beams down.
Technically this is considered a standard sized bed of 6.5 feet. I figured, If I'm spending this much already on a new truck, might as well as get the extra foot compared to a short bed. Umm that I don't know.
It's just the nose on these trucks these days. They are so large and sit higher than the bed which gives the perception of looking nose high. I always keep rake in mine for towing and hauling (car trailer, boat/jetskis, hauling, etc), plus I like it to visually look level rather than measure level.
I hear you on that with getting the longer bed. My pops did that years ago when he thought he might as well get the 8ft bed on his extended cab truck (this was back in '95) since it was more truck for $200, well after getting it and moving down to Texas (he bought the truck in Minnesota before we moved) it didn't fit in the garage. Fortunately, my garage is plenty long, just the parking garage at work is the last issue. I do know the added bed length would be handy and used, then pics like yours sure sway me that way visually as well. Like I said I am still a few years out from a new truck, so maybe I will start a thread on long bed, err I mean standard bed pics.
Looks like only the regular cab in the half ton can get the long 8ft bed, I bet the HD's can get it in more cab styles.
Tyler
Tyler
As you mentioned, there is unfortunately only a single cab long bed option for a 1500.  And only in WT trim.  As me how I know...grr...  If you look back at this thread you can find a few pics of my truck.  Or I can send you some later.
But you are able to get 4 door options and different packages with an 8 ft bed in a 2500.
Seems like a very nice and affordable set up, I’ve been running a  1.5 level kit on my 2020 TB since I purchased it (in 2020) with no issues… however I think that extra 1/2 inch may allow 35’s…. I’m running 34’s (295/18), on a zero offset wheels… how were you able to run 35’s… a bit of trimming ?
I did have to remove the front mud flaps and the bracket behind them.
Got someone else to drive the truck so I could finally get some rollers of it. Whathcha think?
Very nice set up … what wheel  offset did you go with?
Thank you!. They are -12 (fueloffroad Block D751 wheels (18X9, -12 offset))
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
