On 9/25/2018 at 8:36 PM, z1boss said:
Picked up my special ordered 2019 Trail Boss about 2 weeks ago.  Loving it so far.  Lots of mods already.
Nice color, omg
4 hours ago, tioran said:
Nice color, omg
Look's Good
Some off road pictures from the other day
Bought my 2021 Silverado RST Double-Cab 2 months ago, and have done a few moderate upgrades.
She has the 5.3L L84 V8 & the 8 speed 8L90 Transmission with the Z71 Off-Road package w/skid plates & a couple of different comfort & convenience packages.
I fixed the cab rear window leak already - it wasn't a bad leak, but it definitely needed to be addressed and I took care of it in very short order.
Post here:
Added the PPE Transmission Fluid Thermal Bypass Valve, "Range" AFM/DFM Disabler Module, swapped out the stock transmission fluid with Mobil 1 Synthetic LV ATF HP Transmission Fluid, and upgraded the engine oil with AMSOIL 5W30 & Long Life oil Filter. I just wanted the truck to be mechanically sound, so I addressed all of the common, known issues that I was aware of.
As of now I have about 37,600 miles on the clock.
I swapped out the chrome factory side steps with some "Real Truck" off-road side-steps in black bedliner finish, I like that they fit nice & tight, up to the bottom of the door-sills with very little space in between and your feet will NOT slip off of these steps - even when they're wet. I also added the Weathertech hood/bug deflector.
She's nothing fancy, photos below:
Edited by Silver Yeti
  • 4 weeks later...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
