3.08 to 3.73
silveradosid
i have a 2014 5.3 4x4 ccsb with 3.08 gears. i can get a front and rear diffs from a 2014 with 3.73 . i do almost all highway miles and would like to know if this is worth the effort. i do pull trailers ocassionally how much will it effect my gas mileage
To me it would not be worth it.  You would take a nice hit on MPG.
Unless you are going to install a lift and bigger tires there wouldn't be any need to go that high on a gear ratio.
That gear change would make your driveshaft turn 20% faster than it currently does.
That does not translate directly to MPGs increase. But while in drive, your engine rpms will still be significantly higher.
Unless you NEED the torque for towing, I think this change would be a waste of time & money.
I'd look for a new truck before I spent money on changing gears.
Like Black02Silverado said, unless you are trying to turn much larger tires while maintaining the current pep of your ride, its not worth it.
Just now, silveradosid said:
i can get both diffs for 600 buck and yes would be going to larger tires
That sounds to good to be true for the cost.  Make sure they are good and there is no problems with them.
Stock 3.73's only came in the 9.76 rear Axel, and you have 3.08s so you have a 9.5 rear axle.  So unless you are swapping out the entire Axel I *don't know* (but I highly doubt) the carrier/gears will be compatible with your Axel. If I were able to get my hands on that I would probably buy the entire rear axle assembly and the complete front carrier.
This all depends.  My truck came stock with 342 and the 275 55 20 (31.8 tall)
Im now running a 275 45 20(29.5)  and i average better mpg.  Thats not a huge gear change but depending how you drive it should stay around the same.
Since 3.73 is a OEM gear ratio, the dealer should have plenty of info about your expected gas mileage. You should also ask them if they are willing to update your computer for that gear ratio, otherwise you will need a tuner or similar device.
My opinion, without bigger tires, I don’t think you’re looking at a huge difference in gas mileage. Driving habits will likely have a bigger impact than the gears. With 3.73 you’ll likely enter V4 earlier than with the 3.08 so it may equal out to a minimal mpg difference.
If you do put bigger, heavier tires on, it’s hard to say how much of a change you will see since there are a lot of variables. Tire tread, weight, width, circumference, etc... that all will have an impact on your fuel efficiency.
I have 33.5” tires. Each wheel/tire weighs 115lbs. This dropped me down to 12mpg with 3.42 gears. I installed 4.56 gears and it went up to 15.3mpg with 87 gas. During average around town and highway driving, it’s in V4 more than 50% of the time (probably closer to 75%). Highway mpg on 87 gas appears to be around 19mpg.
Being worth the effort is, of course, in the eye of the beholder.  But in my opinion, absolutely it will be worth it.  If you can get the parts for that price, they're in good shape and install/set them up correctly it's a fantastic deal that will make the truck more enjoyable to drive, especially when towing.  Even more so when you add larger tires.  Most here who have a shop install gears pay $2000+ for it (even without new carriers) and typically say it was one of their favorite mods and definitely "worth it" even at that price.
I would expect the mileage changes to be negligible.  You'll take a hit with the larger tires with either ratio.  With larger tires there are many scenarios where the 3.08 gears become more of a hindrance than a help.  If you want the best mileage with larger tires, try and stick to lighter weight/lower rated (P-rated) tires.
Gears are one of the best things you can do. I find the factories way under gear vehicles regardless of the make.
2014 z71 LTZ
Volant Intake
Borla Exhaust
Diablo
Bilstein 5100
Rough Country Level
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
    • Very often the part number on the trim part is just for the vendor order/assembly plant and will not show up in the parts system.  They won't make a bunch of extra parts that were not ordered. Keep in mind, lots of these parts were made to be "just in time" parts meaning they were dedicated to a vehicles ordered and sequenced for assembly.       Also, trim parts will often say, paint to match.
