Hi guys has anyone dug into the radio to see if it is possible to add a front camera to the system?
Thanks for any help
I know the Chevy camaro has the option to do it with some programming I would think the system would have something especially with the over view feature
  • 6 months later...
Thanks for any help
ever find out if you could add a front camera?
  • 5 months later...
Thanks for any help
I'm waiting to see this as well.
I'm guessing this doesn't work with the T1s....  the 2019 inclusion there is for the Limited...  note it needs IO5 or IO6 radio....
I like how the linked one for the last gens has an option to automatically turn on the front camera when your going under 10mph. That's handy as heck.
14 hours ago, Josh99722 said:
Look up mvi, i added a factory dvd and overhead screen, also 360 camera.
the guy is awesome, and very helpful with any questions or problems.
i love having all the cameras!
tell him josh w/ 2016 silverado in minnesota sent you!
https://www.gm-navigation.com/shop/2014-2019-gm-360-camera-towing-system/
That's not for the new body
Bump
I do have a local shop that will install for $1400. To me that is a little too much. I am willing to spend $1000 for a factory install or $600 for a none factory install( still needs to use factory screen).
Edited by BlancoSilverado
Sorry i know its not the t1 style, I would still speak with mvi. Im sure they are working on it. Mvi keeps every retrofit oem.
search ebay for the kits. Bill craigem is a good one, email see what they have.
i would imagine ecomaster would make kits that are plug and play For the newer style.
go to a gm parts website and look through it, probably list the module harness camera in diagrams. Then find part #’s and start ordering parts.
https://www.group1autoparts.com/auto-parts/2019/chevrolet/silverado-1500/ltz-trim/5-3l-v8-gas-engine/body-cat/grille-and-components-scat/?part_number=84400532
  • 3 months later...
I have a 2019 High Country that did come with all the cameras but the front one. I am having my local dealer install it. They said it was a plug and play. Just needed to have the infotainment system programmed. It is VERY pricy but I wanted it. Just FYI. It can be done.
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,481 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
