Sorry.... I just realized you posted that before. Been a long week!
I not sure where to look for the BCM connector, can you help me out?
White connector under your dash. Driver's side.
It's where the green wire is going into.
1 row of pins. 3 Over. It's one of the two gray wires in this connector.
Sent from my SM-N960U1 using Tapatalk
On 12/5/2018 at 11:27 AM, 1FUNC5 said:
 Has anyone had the issue of this power source cutting off and back on when the truck cranks from auto stop start ??????
I am, I was wondering why my dash cam was cutting on and off, it doesn't happen every time though.
Hoping you might be able to help.
I have the same Opt 7 kit as you.  I have a spade powering it and connected to the open prong next to the 50.  That works fine.
I ran the aux wire from the Opt7 control box to the grey wire in the BCM and T tapped into it as I want the lights to power on and off with dome.
I have everything connected and grounded properly, but can’t get the dome feature to power on and off with this kit.
what am I missing?  Do I need a different power source since this one is switched.  Super frustrated.
3 hours ago, Saloonwarrior said:
You mentioned  adding relays for your footwell leds. Is it really necessary with such low current draw?
I still can’t get them to come on and off with the door.  I’ve tried everything.   I have to manually switch them off as they come on every time when I open the door.
I just bought the Opt7 kit. Did you ever figure out how to get it on/off with the domes? I definitely want it coming on when I open the doors but don’t want them on all the time while driving
On 2/1/2020 at 10:04 AM, JAshworth03 said:
I still can’t figured it out.  Mine stay on and I use the remote to turn off.
I'm lost. I have the Opt7 kit fully wired in. Connected the accessory wire to the grey wire (dome light) on the driver side. I tried every spade connector on the passenger fuse box. There's one that's RAP and a few others that are always hot. I want the lights to come on when I open the door or the dome light comes on. With the RAP power, it only comes on if the vehicle is on. With the always hot connections, the lights stay on constantly. There has to be a spot in the fuse box that's door/dome activated... I love the lights but I need a way for them to come on with the dome/door without running all of the power off of that 24 gauge grey wire on the plug...
Exact same boat!!!
  • Sad 1
Yes i have as well, only with my Roof mounted dvd player i installed. my radar detector doesnt shut of thou, so its probably just a drop in voltage causeing the shut off. not a full discharge of power. I just got the Autostop Eliminator and will hope this will just cut the problem out all together as i dont want that feature anyways. save on gas milage my ...
Hooked mine up last night. Wired them into the dome lights. Thanks Smoothbassman!
On 10/22/2018 at 7:54 AM, 2019_Silverado_HC said:
I installed some RGB footwell lights this weekend (picture forthcoming) and part of the project involved locating a switched power source and preferably one with retained accessory power.  In the right fuse panel (passenger side) by fuse F27 which is a square shaped fuse, there is an additional prong next to it that will accept a spade connector which you can then run a wire to a separate fuse for whatever you are installing.  I hope this helps someone else since wiring diagrams are not readily available on the net yet.  Enjoy!
Thank you for taking the time to post your suggestion.  My 2015 Silverado did not have the panel on the passenger side  so I was unaware it even existed. My dash cam now works as it should.
  • 4 months later...
On 2/11/2020 at 9:24 PM, JAshworth03 said:
Exact same boat!!!
Hey guys not sure if your still trying to figure this out but I have the same kit as you. If you want he lights only to come on with dome lights you just connect the power wire to the pin for the domes on the bcm. If you want it to come on when you enter and exit but also want it on while your driving you run the power wire through the grommet to the engine bay and wire it to the purple wire on your headlight harness. That is the parking lights wire. Then run the accessory wire to the dome light wire in the bcm. This is the way I have mine set up. It took me a while to figure it out. For some reason when you try hooking your power wire to the bcm headlight wire it doesn’t do anything. So if anyone is still looking to do this and want it to work this way. This is the way to do it. No relays needed as this kit has a control box. If anyone needs help just message me.
I haven’t messed with mine since the original install, but I really want mine to come on during door open/close and while driving. That setup sounds like exactly what I want. Do you have pictures of where on the BCM it connects? I’m sure I can find the purple headlight wire but I’ve had a hell of a time finding the dome wire, especially since online diagrams are sparse. It would be awesome if you did a short writeup based on the wires you tapped. Thank you for the update, you’ve re-piqued my interest!
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
