On 10/25/2018 at 8:40 AM, 2019_Silverado_HC said:
A couple of pictures...
That looks legit!
Has anyone had any issues with the integrity of this 12V swithced power source?  I have noticed that the accessory I have connected to the metal spade connector mentioned above loses power when I open and then shut the driver door while the truck is running.  Sometimes the device powers back up but sometimes it stays off so it's compeltely inconsistent.  It's for a Antilaser Priority Laser Shifter so definitely concerning when it will randomly shut off while running around town.  Could this be a voltage drop or a ground issue?  It just seems odd that it would only happen when closing the door to the truck.
  • 4 months later...
Hey all! Some great tips in here. Did we conclude that a t-tap into the gray wire on the BCM in the driver’s side footwell is the place to go to power these when the dome lights come on/go off? Thanks!
On 7/13/2020 at 10:56 PM, Alex K said:
I haven’t messed with mine since the original install, but I really want mine to come on during door open/close and while driving. That setup sounds like exactly what I want. Do you have pictures of where on the BCM it connects? I’m sure I can find the purple headlight wire but I’ve had a hell of a time finding the dome wire, especially since online diagrams are sparse. It would be awesome if you did a short writeup based on the wires you tapped. Thank you for the update, you’ve re-piqued my interest!
Alex,
I'd encourage you to look at page 2 of this forum thread. Smoothbassman has a pic and a description of where the correct wire is on the BCM.
28 minutes ago, Daryl Casey said:
Alex,
I'd also encourage you to look at my comment on page 3, from July of last year. That grey wire on the BCM doesn't work as intended
My apologies. I thought that was what you were looking for.
Looking at the GM Upfitter manuals (page 7-250 of the electrical manual) https://www.gmupfitter.com/pdflists/view/45  the electrical connector you want is BCM X1 (white plug) pin 23 (Gray wire) it is the 2nd gray wire on the plug closer to the bottom.(Bottom row, 2nd in from right)The plug wires are numbered if you look at the plug from the side where the wires go into it.
That is the one that will dim the cabin lights. I've tapped into that wire for my footwell lights and they dim just like the OEM lighting now.
Hope this helps,
DC
Edited by Daryl Casey
  • 5 months later...
It's interesting but in my 21' AT4 while my BCM X1 white plug has gray wires in pins 21 and 23, pin 23 does not have significant voltage when the dome lights are on, it only reads about 0.1v above nothing.   Now I did add 2 LEDs to the overhead console and tapped into a gray wire up there and they work fine as per:  https://www.gm-trucks.com/forums/topic/232272-interior-lighting/?do=findComment&comment=2476751
Not sure if that would have impacted things at the BCM plug.  I can also add that if I remove the white BCM X1 the dome lights immediately die, but I have not been able to identify the wire in that plug that appears to trigger them.
It's driving me quite bonkers actually, because so many of the resources say that's the place to tap into under the drivers area, but it absolutely does not work on mine.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
