My 2020, 2500 HD had a similar event this morning: black screen and no radio.  I was going to drop it off at the dealership but everything came on as usual when I turned it on a couple of house after the “black out”.  Always been a Chevy fan but this is not cool on a new truck with 6000 miles.
Greetings everyone.
I have a 2019 GMC with the intellink system and have experienced issues like some of you have been going though.  Being the curious type and love working with programming and electronics I have a few suggestions. Now keep in mind my phone is Android based.  Here a few suggestions that I follow and my system works pretty well.
1. I always turn my phone off every day in the morning then back on before I go to work.  This help clear memory and non working programs from gumming up you phone.
2. Have updates on the phone working. Google is always updating Google Auto and Google maps.
3. If you are going to plug your phone in make sure Bluetooth on your phone is off and make sure Bluetooth is off on the phone before you turn on your truck.
4. If your going to be plugging in your phone I always plug it in the truck before I turn the truck on.
5. If you have to enter a security code to get into your phone make sure you are logged in to your phone before you turn the truck on because if you dont then you will get a blank screen. This has happen to me many times.
6. USB cables are not all the same!  This is important.  If your using a cable from your laptop or some other devise to power up its not going to work well.  If the USB cable has been walked on, crushed, pinned in any way that cable is going to give you issues big time and your gmc truck will be getting issues.  Make sure you have a good, thick data USB cable and dont use the power cable that came with the phone.  Treat the cable like gold.
7. If Google, or Maps or Waze or YouTube music does a big update sometimes the screen goes blank. Not sure why but I give it a few mins and let it do its thing.
8. Last thing, if my fingers are dirty or dusty it will have a effect on the screen.  I work outside in the landscape business and have found the screen likes non dusty fingers.  Dont know why but its life!
Sorry about long post, I thought it would be shorter but I figures this could help out some way. I have yet to do a factory reset on this system.  Sometimes its good to do a reset on systems like this once in a while.  When i get to that point will let you know.    Good luck!
We just started having this problem in our 2018 Silverado. Radio is a complete black out with no sound, nothing! Turning truck on and off doesn’t work. A/C and everything else works fine. Any solutions?
Have you tried a reset? Is Bluetooth on and its connecting to your phone?
This is my second month with my 2020 Silverado custom 1500 and the screen came black and I can still listen to the radio but I cannot change the station or see anything except the backup camera I tried to use on star and is not working as well
update quick fix is to let off the  truck for 10 mins after exit . This will reset the unit .
This just started happening to mine this week, adding to the long list of issues I've had with it.   It mostly happens soon after I've started the truck, camera will work then screen goes black, sometimes radio will come on, sometimes not.  It has fixed itself everytime, but sometimes will take less than a minute other times 10-15 minutes and twice after restarting the truck.
Better than when it was playing music from my phone and the radio at the same time and was unable to change anything, but I'd like to go more than 2 weeks without having some sort of problem with this truck.
My 2019 Silverado Custom has had this problem for the past 6 months. Screen frozen, cannot find phone and blacking out. Very frustrating. Contacted the dealer and they replaced the display but it did help. This is my second Silverado that did this. As soon as possible, I will switch to a Ram. Chevy does not know how to fix their own product on a 40 thousand dollar truck. Lost confidence and will not recommend Silverado trucks when asked. This is a vital feature to the truck not to work reliably.
Good luck with the infotainment system in your new Ram. They're notoriously bad, too.
I have a 2020 All Star Edition with just under 3k miles. The black screen happened to me today when I went to run an errand. Shut the truck off multiple times including exiting the vehicle and locking from the door and fob. But nothing helped. Got home and let the truck sit for a couple minutes and then went out and it turned on like normal.
Made an appointment with the dealer but seeing as it's working again I'll just have to cancel it since they won't see any problems.
My infotainment went out for almost a whole day with a different issue. After I let it sit overnight it was working fine in the morning. These are the worst kind of problems since you cant duplicate it at will. I hope they do some more software updates to fix this, the system seems pretty buggy.
The only way that I have been able to prevent this from happening to me,  is the following....When i get in the truck to start it , I put the keys in the ignition, then turn the keys to accessory position only, and wait. I’ll let the heads up display screen “cycle through”, and get fully past the “Chevrolet symbol”. Wait till the screen gets to the “home screen“, and then start the truck. When I start the truck the screen will go through one more cycle and go back to the home screen. THEN, I unlock my iPhone, and then plug it in. When I do this exact procedure, I never get a black out on the Silverado screen. However, if I just “jump in the truck and start it very quickly“, or plug the phone in during the boot up cycle, or while the phone is locked, I will get black screen.
doing the first method listed above, has been 100% fail safe. (For me). Three months without a black screen so far.
I don’t know if this will help others, but it has 100% fixed the problem for me
my assumption here is that as we start our trucks very quickly and the key slides past the “accessory“ position, the computer system starts booting up, but as it is turned past the accessory position rapidly, then to the “start\on“ position. The computer is powered off and then back on again very rapidly. The computer almost seems to “hiccup“. I don’t know if this helps anyone, but this has been my observation. It has 100% avoided the black out issue for me.
It’s almost like pressing the power button twice on your desktop computer very quickly. Not good for it.
These are just my observations, and I do think it’s possibly a design error on the manufactures part. However, this seems to be a “workaround“.
I hope this helps someone.
Edited by Brizzo Jenkins
Punctuation and grammar errors
We have a brand new 2019 GMC Sierra..currently 4 months old, less than 4,000 miles.  We got a black screen and can’t even turn the radio down.  We tried turning the car off and on & no change.  We turned it off and tried reading the owners manual & cranked back up after about 5 min.  The screen came back on.  Pretty bad this is already happening on a brand new truck...hope it’s not foresight into what’s to come...
Edited by Erin
Misspelling
I’ve got a 2020 LT Trail Boss with only 6000 miles on it. Same issues here with screen being black, but at start up the truck would not start and stated it was in battery saving mode. Just saw where GM has a recall for 19-20 model trucks due to battery connections being faulty.
https://www.consumerreports.org/car-recalls-defects/gm-recalls-full-sized-pickup-trucks-due-to-battery-connector-problems/
I've had all the recalls done and mine still blacks out.
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 446 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
