10 speed vs 8 speed 6.2 L
Anybody coming from a previous generation 6.2 feel like these trucks slowed down some with the new 10 speed ? I test drove a Sierra Denali and Escalade 6.2 which both of which felt alot slower than the previous gen with the 8speed did in a 200-300lb heavier truck.Thoughts ?
I had a 2016 Yukon Denail with the 8 speed and it felt a bit quicker than my 2019 Silverado 6.2.  Granted, I haven't been into it too much during break in.  The times I did get into it a little it responded and when I realized how fast I was going, I backed off.  I think they're as fast but just don't feel as fast.  Maybe less NVH compared to previous generations.  I believe it was C&D that tested a 6.2 in one of the trucks at 5.4 seconds compared to 5.8 for the last gen.
Interesting.I receive subscriptions from all of the major magazines and Car & Drivers numbers are always all over the place for some reason.In the latest Motortrend issue they compared all of the 2019 trucks from all the major makes on the same day.Those results seem to agree with my seat of pants about the 10 speeds when you factor in the differences weight
2016 Denali  6.2 8speed 5733lbs 0-60 in 5.8 1/4 in 14.2
2019  AT4   6.2 10speed 5466lbs 0-60 in 5.8 1/4 in 14.2
2019 Denali 6.2 10speed 5595lbs 0-60 in 6.0 1/4 in 14.4
2019   RST  5.3  8speed   5178lbs 0-60 in 6.6 1/4 in 14.9
  • 2 months later...
I should be picking up a 2019, 6.2 w/10speed tomorrow.   Currently have a 6.2 with the 8 speed.  I'll post up my opinion later.
I don't think that the 10-speed is made for drag racing. After all, there are a few more shifts to be done to reach the desired speed.
It's more like for fuel economy WHEN you're using the truck as a truck and WHEN towing trailers AND boulevard cruising, which IMO is the new battle field for the higher end trucks.
so long
j-ten-ner
I've only got about 40 miles on my new one so far.  The 10-speed is a different animal than the 8-speed for sure.  I've always found it difficult to feel like a big/tall vehicle is fast anyway.   The extra gears definitely make it tougher to follow the shift points.   I did bear down on it just a bit, honestly it made me think of the allison transmission I had in my 2002 duramax.  To me, the duramax/allison seemed to shift at pre-defined speeds, not rpm when I was hard accelerating if that makes sense.
  • 4 weeks later...
The 10 speed is in the top of the line ZL1 Camaro with the 8 speed in the SS versions.  The amount of speeds doesnt necessarily dictate drag racing or mpg.  It is how it is programmed to shift.  The fastest production Camaro has a 10 speed.
It has to do with programming too. Some of the reviews I’ve read have the trucks slower with the 10 speed.
  • 5 months later...
I've got the 2019 AT4 6.2L 10 speed with performance package traded a 2017 Silverado LTZ 6.2L 8 speed. Had both dynoed, the LTZ made 365 hp, 390 tq, with GM's Borla exhaust and K&N Cold Air Intake, AT4 made 346hp 370tq, with there performance package, big difference. Changed to K&N Cold Air Intake on AT4 it made 360 hp 385 tq, GMs Cold Air Intake is GARBGE. And I gained about 3mpg. O, and I took the AT4 to the drag strip 1/8 mile, before filter change, 9.8, after filter change, 9.2, big difference here also, truck has about 9000 miles on it.
I have a 17 6.2/8 speed crew AT and my wife has a 19 6.2/10speed crew AT4 and the 10 speed doesn't yet behave like my 8 speed does. The 10 speed is smoother and the shifts are precise and non-clunky thus far. It feels as quick as mine(pre-lift) and I was thinking maybe a touch quicker...not sure.
Her old ride was a Yukon Denali 6.2/8 speed. What I can tell you is the throttle map on the Yukon with 6.2 is more aggressive than the trucks. I'm sure so.eone who has owned or driven both can chime in.
Sent via Morse code
Good info. Thanks for sharing
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
