Tailgate not flat with bed when open (slight angle up)
My gate is slightly angled up when opened so when loaded with say sheets of drywall the gate and cables will take more stress than if flush with the bed when open. I wonder if this is just mine or is as designed for all 2019s?
Side note one of my cables is slightly looser than the the other even when sitting on it. Searching this seems common on the old models - anyone else have this?
Might gate is slightly angled up when opened so when loaded with say sheets of drywall the gate and cables will take more stress than if flush with the bed when open. I wonder if this is just mine or is as designed for all 2019s?
Mine sits flush. I've already had boards in it and there was no angle.
Sent from my SM-N960W using Tapatalk
Mine has same problem, slight angle up
Wonder if it's an issue with the cables being slightly shorter?
They have all been this way for some time. I'm shocked that more people don't notice. I guess hardly anyone uses that big box in the rear. I made a similar post when I bought my 2015.
I ended up buying a set of these to "help" fix the angle of the tailgate.
http://www.ridertailgate.com/copy-of-gm1-tailgate-lowering-link-set/
I'd like to purchase your tailgate cables. I'll even throw in mine for free.
I've never noticed it to be as pronounced as OP is describing though.
Haha!
I'll get a picture when my truck is back from having the front end wrapped with clear shield.
Normal.
Quote
#PIT3227P: Normal Characteristic - Tailgate Cable Slack - (Dec 17, 2018)
Supersession Statement
This PI was superseded to add the 2019 Model Years. Please discard PIT3227N.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some customers may comment that with the tailgate down, one of the tailgate cables may have slack in it or one cable may be perceived to be longer by the customer.
Recommendation/Instructions
Important: If involved, complete the latest version of Campaign 04007prior to referencing this information.
No repair attempts should be made as this is normal due to build variation. In most cases, when weight is put on the tailgate, the slack comes out of the cable.
Customer Information
Please communicate to the customer this condition is a normal operating characteristic of their vehicle. It will not impact the designed performance or reliability of the vehicle. Please share this information with the customer, including a copy of this message.
Don't know if the cables are different on mine or not, currently raining cats and dogs out so not going out to garage to look at the moment. I'm taking my truck in Friday for another issue and I'll ask about it.
If I had to guess I'd say tailgate alignment, not cable length.  Cable length is probably a lot easier to make consistently than all of the other bits involved in making sure both sides of the gate and truck are even.
I put mine down for the first time today, same thing, not level.
I looked at mine this morning and the cable on the left side is tight and cable on right side is not. Going to take cable loose on the tight side and see if it lets gate lay flat. After the blizzard blows through that is :)
