I drove a car that had a Pedal Commander installed yesterday. The throttle response was night and day and it was like driving a completely different car. It painted a smile on my face every time I romped on the gas. I was wondering if anyone has installed one on on their Silverado (previous/new gen)?
I do not work for Pedal Commander
I do not sell Pedal Commanders
Im asking if anyone has installed one because I've heard they work better on some cars than others...I dont want to waste my $$$ if they dont work well on Silverados.
I have the same thing but a different manufacturer on my CTS V.
Vittness Motorsport $179.00
Make the vehicle more responsive
Does not add horsepower. .
Sent from my SM-N910V using Tapatalk
Go to www.vitesse-motorsport.com check them out they make them for our truck
I have one on my 17 Sierra, definitely makes in more responsive and you can dial in how much response you want. They have great customer service also. My controller was all scratched so I emailed them a picture of it and they sent me a brand new one super quickly.
I have one on my 18 Colorado with the 3.6. It’s set at City -1 and it makes a big difference.
Website link does not come up. The correct one is www.vitesse-motorsports.com     The "S" must be at the end :thumbs:
Thanks for the recommendation and the link!
Im surprised this mod isnt more talked about and added to the "must have" mod list. Manufacturers have baked in awful throttle response for improved MPGs (including sports cars) which sucked the fun out of most cars.
The mod is definitely worth every penny with the smiles it paints on your face...especially since it doesnt void your warranty.
Edited by Chris walker
This programmer is much cheaper than Pedal Commander or the other brands.
$180 is not bad if it provides the same result as other competitors.
  • 3 months later...
Installed a Pedal Commander this weekend and love it.   Running in sport -2
Not sure if I'd want a better response. The Ford F-150 had really mushy gas pedals which I got very used to then drove my friend's 707-hp Dodge Hellcat. I hit the gas pedal and the rear tires smoked for a very short period of time when I realized what I was doing. Unfortunately, the motorcycle cop was right there and I now have a $470 exhibition of speed ticket.
  • Sad 1
Is there a way I could make it more mushy? I kind of like that.
Yes... it can increase or decrease the response.
So I guess they have one for the 2019. Can you post a link to what you purchased?
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
