I know a lot of departments here won't respond if it is a non-injury accident. Basically you have to respond to their station to make a report. Here in Ohio, many agencies also have a self report form. I've heard of too many people trying to work a crash out amongst themselves, only to end up getting the run around. I'd suggest going to the PD to see if they'd make a report there, and if not, see if they offer a self report.
Yes, they direct you to a self report form.  I am asking advice from a buddy who is the assistant chief of police in a neighboring county.
5 hours ago, M3Master said:
My agent has actually been really nice about this.  I'm sure it's not him that makes the call on how stuff counts against you...its the insurance company.  That said he has been very supportive in handling however I want.   He just recommended the safest way was to give Amica the chance to handle it in full.  If I'm happy w/ the way they handle it, then let them handle it was his advice.,
I understand he is saying that whether I was at fault or not, a claim is a claim.  And even not at fault claims affect how the parent company assesses risk.  While I understand that, it truly sucks for the customer when they are not at fault.
I guess my point is, if you have a clean driving record, this should not affect you in a negative way. And you pay for their service, let them "bully" the other insurance company, what happens if you do something wrong, say something wrong, you get the point, your insurance is still going to bill you the next month while you are doing all of the work. Just sounds like they would  like you not to use what you pay them monthly for.
On 1/10/2019 at 8:43 AM, M3Master said:
Not exactly a mods related topic but I figured I'd get some feedback.
Technically it is modified....
So, things finally came together.
  • Amica appraiser came out.  Initial damage estimate is 8500.  No structure damage.  No electrical damage.
  • Amica talked w/ their customer.  They have formally accepted liability.
  • They have sent a tow truck to pick up my truck and take it to my shop of choice.
  • They have authorized a truck as a rental.
I'm a bit relieved!  Thanks to everyone for all the input.  Get a dash cam!
  • Like 4
That's great news.  I had a feeling Amica would pony up - they have a good reputation as far as claims go.  Glad things are working out!
On ‎1‎/‎10‎/‎2019 at 9:21 AM, M3Master said:
All, I really appreciate the advice.  I'm just sick that my new truck is damaged.  And of course all the guys at work are telling me "you're screwed...it'll never be the same".  I really appreciate the support.
 First rule, never listen to the guys at work. If they are like anywhere I have worked they are drama queens who live to pump you up. Your truck will easily be fixed as good as new. Although costly, it looks like no big deal.
No structural damage equals easy although expensive fix but easy nonetheless. That really means that your trucks should be as good as new if not better than new due to probably not having a poor GM paint job anymore.
Edited by eppieguy
too many typo's due to ipad and me not paying attention
  • 2 years later...
Glad it worked out for you. Get truck fixed and enjoy truck.
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 437 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
