4 hours ago, ajensen383 said:
One new thing that happened over the weekend...This only happened once so im not sure if it will be an on going issue... Driving home on the highway, pulling a light grade in 8th gear.. I went to pass a truck so I gave it some gas. Usually It will downshift into 7th and then when I let up it will go back to happily chewing along in 8th...This time it felt strange in the downshift, not even sure how to explain it, like it was caught in between gears and wasn't a firm downshift as usual, almost soggy feeling . It would not shift into 8th not matter what until I crested the grade. I tried going almost 80 and letting off slowly to make it shift, I tried manually putting it in 8th, nothing would get it to shift... After I crested the grade  it was fine after that but wondering if it will happen again...
Were you in Tow-Haul mode maybe?
Got my 2017 6.2 back 2 days ago after getting the dealer to flush with the new fluid. I've only put about 100 miles on it but so far no shudder. The truck has 34k miles now and the trans has never felt this good. The truck has been to the dealer about 5 times for the trans acting up. They usually just update and perform a trans relearn which didn't ever help. This is the 2nd time they've flushed the trans. The 1st time they flushed it helped but still had the occasional shudder. Now it feels like they finally fixed it.
Sent from my SM-G950U using Tapatalk
A few NMD red miles after the fluid swap ....
Upshifts from stopped feel a bit more prounounced when first starting out ... less so after awhile (thinning fluid as trans fluid temp rises?)
As I brake approaching stoplights, I keep waiting for the big CLUNK I used to get - between second and first? Kinda feels like I wants to clunk but doesn’t.
No shudder of any kind at any speed ...
Is the fluid swap an option for the 6 speed? Any TSB’s?
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
On 1/13/2019 at 7:08 AM, bigman32hockey said:
My brand new '18 Redline Editon developed "the shudder" at around 450 miles.  Mine seems to shudder worst when around 50 mph and constant speed and again between 65-70 mph, where it will do it all the time.  I went to my dealer and was told GM will not reimburse them when they install new torque converters for this issue.  Apparently GM has issued a document (Document ID: 4536930) which says GM engineering has proven the problem is not caused by the torque converter.  The only fix my dealer can offer is the transmission fluid flush and fill with Mobil 1 synthetic.  I know this won't fix the shudder problem, but at this point I have to go through the steps GM offers.  I honestly cannot believe I am having this problem.  I had a '17 Midnight Edition that I traded up from (wanted the 6.2L engine and a few other options).  That truck ran perfectly.  Never had any problems with it.  Less than 1,000 miles on the new one and I regret the day I drove off the lot with it.  Now every time I see another Silverado on the road, I wonder to myself, "I wonder if their truck drives correctly?"  It is ridiculous that a $60,000 truck rides like crap.  I mean, how can GM expect me to be satisfied with this purchase?  If this problem isn't fixed after three attempts, which I doubt it will, I will be hiring a lawyer and proceeding with a Lemon Law claim.  For GM just to say they are aware it's a problem but don't know how to fix it is not acceptable.  Are others out there in the same situation as me?  If you got your's fixed, how exactly did you do it?  Thanks.
I have a 2018 GMC 6.2L 1500 does the shudder just took it to dealership the manager calls me and says there is nothing wrong with the truck.   I'm picking it up in morning.  Afraid I'm going to lose my shit on these crooks. Shakes like hell everyone that's ever ridden in it mentions it.  We'll see what happens tomorrow.
On 1/18/2019 at 9:51 AM, ajensen383 said:
I have to agree with this.... You usually only hear about the bad ones...although there are a lot of people that may or may not have issues that don't know about this forum either.. But this does sound like a pretty big problem for GM since its not only our trucks..Camaro and Corvettes have the same problems..
I have my 2018 truck about a year now and 8500 miles and I don't have any issues with mine... My only real complaint is when doing a rolling stop and getting back on the gas it will act like its in neutral ( rpm goes up while coasting ) then slam into 1st... if I actually stop, there are no issues... I tried different speeds on the highway and no shuttering at all...so far
Just throwing it out there my 2018 was built in 11/2017 , not sure if time of build has anything to do with it
I know the 2015-2016 trucks had a lot more issues than the 2017-2018 models do., but I wonder how many 2018 models have this issue?? Most of the posts on here are 2015-2016 trucks, there are not too many specifically on the 2018s yet.
2018 GMC 6.2L Sierra shakes bad, dealer told me it's normal.  Picking it up in morning.
Are you having issues with your 6 Speed?
Sent from above
Sent from above
Yeah it has its problems here and there
I’ve heard that the 14-15 warranty is longer and goes further on your transmission versus my 18. It should state it in your owners manual.
Sent from above
Sent from above
GM used to have a 5/100k powertrain warranty, however they knocked it down to 5/60k in either '14 or '15
Edited by jimmyboy8301
Sent from above
I will check it out. Took it into dealer before to have it checked. Left it for the day and I was told my oiled k&n Cai is the problem. They say oil probably got on the MAF. They didn’t even take my truck for a test drive. So I was told to put stock air intake back on they will clean the mAF and then do a trans relearn. Still haven’t taken it back yet.
How many miles do you currently have?
Sent from above
Sent from above
47K
    • My house is set at 75. My car at 70. When I have guests the house is at 70.
    • OK you say you could hang meat but what was the actual temp? One of the AC systems job is to remove humidity that we feel on our body your new system removed alot of humidity as that is were the water comes from on the ac coils and that made it feel colder. 80 degrees with high humidity will feel hot vs 80 degrees with low humidity will feel alot cooler.
    • I was using recirc/max air. Especially if it really hot i start out by lowering the front windows a little with regular ac the go to recirculation after a few and rolling windows up. And it does not have the newest refrigerant. It has per the info under the hood r134. Not the new r1234yf.
    • tldr; Shade tree mechanic stumped by variable displacement AC compressor.   Not Silverado related, but for my 2000 Camaro SS. I've never really used the AC since acquiring the car a good handful of years ago. I plan to take it on a trip this summer so I wanted to make sure the AC was in good shape. On an 73 degree day in the shop with the car idling I set the AC on "Max", temp set to cold, and fan on hi. The compressor turned on and air turned nice and cold.   I let it run for several minutes but noticed the compressor never cycled off. The engine was up to temperature enough that it began cycling the cooling fans on high. I had a set of manifold gauges hooked up and it was consistently at about 25 psi on the low side and between 200 and 225 psi (warm engine) on the high side. Per temperature charts, the low side is low (should be 30-35) and the high side is a little high (up to 170 per chart). I read the low pressure as potentially being under-charged underscored by a continually running compressor This was also underscored by temp readings of mid-20 degrees at the vents. Not just cold, freezing cold. Switching off the AC but leaving the HVAC fan on high produced a deluge of condensation underneath the vehicle. I was getting ice buildup on the evap core most likely.   The low reading (25psi) concerned me that the compressor wasn't switching off so I swapped out the pressure switch. No change in behavior, still ran constantly.   The AC clutch works fine as it engages/disengages with the HVAC switch on command. The compressor relay is good as I swapped it with two different known good relays just to be sure. Having eliminated that, and the pressure switch, I added refrigerant, thinking the constant run and low "low" pressure were signs of a slight undercharge. Makes sense, the car is 26 years old and it doesn't appear the AC system has ever been touched.   Adding some R134a didn't meaningfully change the low side pressure. And that's when a lightbulb flashed upstairs. While I consider the car "old", it's possibly "new" enough to have a variable displacement compressor. Did some reading and sure enough. Dangit. I don't work on these for this reason.   Adding refrigerant means the compressor will just compensate and won't really change pressures until it's severely overcharged or undercharged. But at least I wasn't getting ice/frost anymore, but instead high 30 degree temps out of the vents. That's more normal, but with variable displacement now I have no idea where my charge level is at. It's probably overcharged now. The high side even with the engine radiating serious heat was never really over about 225.   The static pressure at room temperature is dead on, before and after the charge. Both high/low equalize after some rest.   I'm thinking I'll need to take it to a shop. I want the proper charge level so I'm not working the compressor too hard. The only way to get an accurate charge is to evacuate and then re-charge with the exact amount specified for the system -- at least that's what I'm reading.   Anyone here with modern automotive AC knowledge?
    • Mine is in the shop for the AC now. While it did get cold after a bit, it would take a while to even start to cool the air at all. Turns out the compressor was bad and cycling.
