Big cold snap coming. Washer fluid/anti freeze advice
17 minutes ago, redwngr said:
image.thumb.png.f6086d120330511d1b05ad780610e431.pngEquivalent to about -50F
image.thumb.png.65ada9fb1bd60f4656315b40855cb7dd.pngThis one good to about -56F
I've never seen either of those around here . Must be Canadian only
  • Replies 32
You must be watching "The Weather channel"
They name snowstorms[emoji1787][emoji23][emoji2]
It's not that big of a deal really. It's going to be 20 above by next Saturday.
I was just wondering what the Canucks do when it's that cold that's all
Saw this https://apple.news/AoOZr4TewQg2z2dnPtEbJGA
Sent from above
Horrible for the environment! [emoji1304]
Sent from above
Sent from above
Not surprised that the media is jumping all over this .
This happens every year around this time this just happens to be a little colder than usual. I doubt any records will be broken around here anyways. Hell this is only a few days . I remember about five years ago it was below zero for like twelve straight days
Minneapolis had 54 days it was below zero that winter . Remember the polar vortex?
4 hours ago, kickass audio said:
if that's the wind chill you will be fine. I only have the washer fluid freeze just at the nozzles and it's usually only one nozzle that freezes. Once I start the truck and ride around for a bit it thaws back out. I found that my washer fluid jets would freeze more often if I didn't use the fluid. My thought is that the alcohol in the solution evaporates in the line where it is near the nozzles and that's where it freezes. I used to have to take a heat gun to the wiper cowl on my silverado and my old envoy since I don't use the washers that often. Now I like to squirt them every 2 weeks in the winter at the least and never have issues unless snow melts on the nozzle and freezes but that is no fault of the fluid.
Antifreeze would be fine. I doubt you would be that cold to freeze the antifreeze and blow out the freeze plugs on the engine.
If you want to help protect your washer fluid just add more alcohol to it. That's essentially what keeps it from freezing is a higher alcohol solution.
Put some of that aged 1 year J. Carver bourbon in there. About all it's good for.
1 hour ago, TXGREEK said:
Sent from above
Thinking it is just rubbing alcohol, or lighter fluid, probably could drink it and live (happily) if you went off of the road. Could only imagine what your paint would look like after it sits on it all winter.
Sent from above
I wouldn't worry about it too much. Just don't let anyone or anything drink it. It has a very low vapor pressure, and evaporates quickly.
Grizzlyltz
She got down to -44 this morning and the cold wave ain't even here yet. I bet it hits -50 this coming week. This is why I asked about washer fluid and anti freeze.
Brrrrrre
Brrrrrre
I’ve got a heater system in my garage and I live in Texas lol
Sent from above
I’m currently on the deck drinking a ?. It’s 51F out. Was 18F this am. I’m in high elevation AZ @ 7000’. We average 100” of snow a year but the sun is so intense at this elevation we usually get several 50 degree days during winter.
Have some relatives in the crazy cold area and they are not looking forward to it!
Brrrrrre
Good Lord man...and here we complain about +44 stay safe.
1 hour ago, njk4o5 said:
I assume that -44 is the wind chill? otherwise your coolant in the motor might have some trouble
That's was the actual temperature at 7am Sunday. No wind-chill added
My coolant is good to -40 so I'll be idling my truck for hours if it dips down below-40.  I don't want problems
Add a little puff of wind and the wind-chill is about -60 F.
The forecast is similar to this .
Here is a picture of my TV . I didn't get the whole screen in my other post.
I am considerably North of International falls, Saturday was -40f before the wind, so -45f with the wind factor, -50f at 70mph going down the highway and we have one more week of that BS yet. I have had problems with WWF this year already, I buy big barrels out of Winterpeg for my service trucks and Class 8's for the bulk price. Their mix must have been a little water heavy last round, so I added a 4L jug of generic non-diluted AF to it and it cleared up. The Chevy nozzles like to freeze, especially if you don't get all of the summer stuff out before winter hits. You should be good with most brands, if you have issue freezing the nozzle just add a little pure antifreeze, or airbrake antifreeze (or cheaper straight methanol) to your bottle. You wont have any issues with the engine's coolant at that temperature unless GM uses a different coolant (or temp rating) in the US? I don't run a winter front on any of my GM gasoline trucks. Does your truck have an engine block heater? Because if your truck is not used to starting in temps that cold, they usually wont haha.
I got a block heater but my truck is brand new I got just under 2000 miles on it. It better start. I might just plug it in at night though. No sense in beating the hell out of it just to get it started. I put in some prestone washer fluid good to -35F and i might just get some better stuff when I get up there because all I can find in Minneapolis is -35 .
    BigJake
    BigJake
  • Who's Online   4 Members, 0 Anonymous, 609 Guests (See full list)
