On 3/31/2020 at 5:30 PM, alexistence said:
Since I guess it's been a couple of weeks now, have you noticed any drain on your battery that would be more than leaving a phone charging inside? I would like to run it hot and I hate that the USB won't charge my phone with the engine off.. which is a terrible design flaw if you ask me. I'd like to be able leave the phone on the console and have it charging while I'm at work.
Nope, no noticable battery drain.
I just ordered this wireless charger which others on this forum have installed (I think...) in the center console lid.
CHOETECH Dual Fast Wireless Charger, 5 Coils Qi Certified Double Wireless Charging Pad
here is the issue:  the charger works when I plug into the wall outlet. When I plug into the USB in the center console the light comes on but does not charge when a phone is placed on it. I tried a regular charging cord plugged directly into the phone and it charges, so it is not the USB outlet in the truck.  I did this without mounting it, just loose on the center console, so it is not the thickness of the lid and cover on the phone that prevent charging.
any suggestions?
thanks for the help!
Edited by pschne1
Add more info
The USB on the dash probably doesn't carry enough voltage or watts to run that thing. It charges phones slow...
I bet it carries enough to power the LED on the device, but not enough send power to your phone. Try to hard wire it??
Edited by alexistence
Hard wiring is an option, but would prefer to avoid having to tear apart center console. I am wondering if getting a USB C to USB C cable would work. The plug on the charger is a UBC C but the other end of the cable is the old, larger USB connector. I see cables with USB C on both ends available. I wonder if there is more power supply using the USB C jack in the console?
The built in USB ports didn’t provide enough power to effectively power up the coils in my charger mod either.   Run a hot wire into the console and use a quality 12V USB adapter to power the charging pad.
Also - you don’t have to tear apart the center console to run a wire, you can easily tuck a wire up under it, and the rear of the console (where the vents are) comes off extremely easily, so you can access the inside of the console.
Edited by romclean1
Even plugged into the smaller USB-C outlet?  I thought those charge faster.
The only way to know for sure is to test with a meter. I bet that they are both the same though.
On 3/1/2020 at 8:49 PM, Fyreman97 said:
This is how I decided to do it for now. Want to wire it in so I don't lose the USB port on the dash.
Which wireless charger is that?  Looking for one that I can just plug into the USB port and not hardwire in.
It was from Amazon. It says currently unavailable
FASTPAD Ultra-Slim Qi Wireless Charger PU Leather Wireless Charging Pad for iPhone 11 Pro iPhone X XR XS MAX / 8/8 Plus 7.5W Fast Charging, Water Resistant, No Heating (No AC Adapter) https://www.amazon.com/dp/B0793TJ9YR/ref=cm_sw_r_cp_api_i_Ds7IEbSG37WGF
I have a 2020 Silverado LTZ without wireless charging, I was wondering if you bought a new console insert with the wireless pad is the factory wiring underneath to plug in? That would be the way to go for a factory look.
I have a 19 TB. I ended up using this wireless charger:
CHOETECH Wireless Charger, 3 Coils Qi Certified 10W Max Fast Wireless Charging Pad, Compatible iPhone 11/11 Pro/11 Pro Max/Xs Max/XR/X/XS/8/8 Plus, Galaxy Note 10/S20/S20+/S10/S10E, AirPods Pro https://www.amazon.com/dp/B07D2CWBS1/ref=cm_sw_r_cp_api_i_zp2KEbMZYJ09C
i took the top off and epoxied it to the underside of the center console. The inside of the center console pops right off and i ran the wire out by the hinge.  I hid the wire and plugged it into the USB in the center console.  I tested it and it works perfectly.  Strong connection even if you slide the phone around in the center pocket on the armrest (I have an iPhone 10 Max).  Phone gets slightly warm when in there for an extended amount of time. I had to drive 1.5 hours yesterday and it was in there and charging the entire time even when using Waze.  All in I spent $20 and about an hour (once I found a wireless charger that the USB port in the truck could power). I assume that buying the factory parts would be way more expensive and do not know if the wiring is already there.
any suggestions?
https://www.amazon.com/gp/product/B08336XQR9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B07V71NQ19/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I had the same issue.  Found this adapter for the cigarette lighter and has higher output.  Then invest in some right angle usb/usb-c plugs.  I didn't know that middle piece came up like that on the console.  I might have to try relocating mine underneath like what you have pictured.
I have been looking into adding wireless charging to a 2020 LT Trail Boss. It took a little digging and found the factory components on gmpartsdirect.com. The total cost is $108, and here are the required part #'s.
#84482763 Wiring Harness (w/o rear heated seats)
#84505586 Upper Trim Panel
#84002462 Wireless Charging Module
The only thing I'm not 100% is whether or not there would be any firmware requirements, or if it is a simple plug and play situation.
Did you ever get it hard wired in or did you just leave it plugged into the USB port?
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 562 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
