Threadlocker on caliper bracket bolts
Anti-Seize is a lubricant?  Whatever, keep putting it on your brake hardware if it makes you feel better.......
I know you're referring to diyer2, but I want to be clear about me putting anti-seize on my brake bolts. It is only applied to the threads in a thin layer that won't glop onto any part of the pads/calipers. For the sliding pins I use grease for lubrication. I took the OP's question as what gets used on the threads. There is nothing wrong with blue threadlocker being used. I was just speaking from my experience of having rusted/seized bolts in the past and never having an issue with bolts coming loose after applying anti-seize on the threads.
This is hotly debated in a lot of automotive forums. There are guys who use nothing, guys who have used anti-seize for 30+ years with no issues, and guys who have only used threadlocker. The real question is does blue threadlocker prevent rusting (the OP said he lives in NY where they salt their roads)? From other replies on this thread, people are saying it has the same properties as anti-seize and won't allow rusting. Living in an area with salted roads and precipitation throughout winter, I think we can all agree applying nothing is a mistake unless you replace your brakes often.
To the OP,  sounds like applying blue threadlocker should do the trick based on what others are saying about it preventing rust. You'll have peace of mind that the bolts won't come out and should not have a rust issue next time you do your brakes.
On 2/25/2019 at 1:15 AM, HeySkippyDog said:
If I put anything on the threads of bolts like that, it would be anti-seize and nothing else.
I did not use anything on them when I did brakes on my 2014, but I live inland in FL and we do not have salt exposure.
Torqueing them to about 35-40 ft-lbs is probably all it needs. There were 3 of the bolts if I remember it right. I did not put a torque wrench on them, I have a pretty good calibrated hand. Nothing has worked loose.
Sent from my SAMSUNG-SM-J727A using Tapatalk
Can't speak to the K2; I haven't had to touch my brakes yet, but on my 2008, torque specs called for 100 ft-lbs on the caliper brackets and 50ft-lbs on the caliper mounting bolts.
Understand and yes he should use BLUE 242.
But not with anti seize on the threads.
Guys, Please use Loctite 242 Blue on your caliper bolts.  Use Loctite 262,272 on Your Caliper Brackets!  This will not cause rust and has properties to inhibit rust/corrosion!
Your not going to anneal the hardware at 500f to break the caliper bolts free!  PLEASE DO NOT USE ANTI-SEIZE on your break hardware!!!!!  Absolutely NOT!
You’re probably one that is completely against using anti-seize on Lug bolts/nuts too...
Actually? Yes. Have a look at the MSDS for you favorite. Nickel, copper, graphite or aluminum in a heavy paraffinic carrier. In fact it is over half heavy distillate. If you consult someone like ARP Fastener Corp it's such a good lubricant that it needs to be taken into consideration in adjusting torque specs.
This will make you butt pucker. I use nickel ease on sparkplug threads in alloy heads. Started this after my first seized plug cost me a cylinder head on an antique Triumph.
Me?  No, I am not against Anti-Seize at all.... I am against that product being used in places where it should not be used?
I was referring to the caliper bolts. I left the brackets in place.
If 50 is the GM spec, I wasn't terribly far off the mark. Higher grade steel in the bolts can handle higher values.
But to put things in perspective, the caliper would need to be able to move laterally and overcome 3x the clamping force of a bolt at whatever the torque value is to come loose. The caliper can't move laterally, the rotor is in the way. So it can't exert really any force against the bolts axially. The bolts would only be subject to forces in shear along its length, and there is plenty of thread engagement at the end for that to never cause backout.
In essence, as long as you pull them "slip-a-fart" tight, your brake caliper is not gonna liberate itself from your vehicle. But, as an engineer I understand that all things must be quantifiable for consistency and CYA situations.
The manufacturer understands my point of view as well - anybody ever seen a spare tire lug wrench that verifies torque? The fact of it is the lugs don't have to be insanely tight - there are 5,6,8 or more of them. The wheel is not able to exert a side load strong enough to break that.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
