04 Suburban No Crank
Okay, hoping to shortcut this diag process.
04 Suburban Z71.  6.0 LQ9, but that is irrelevant to this issue.
Wife's ride.
No crank.  Plenty of battery power, that's not the problem.
I know of the key cylinder issues.
However:  The starter relay clicks when you try and start it, but no sound at all from the starter.   I think if the relay is being activated, that means the key cylinder and wiring in there is good, right?
So if that is correct, I'm down to either the wiring from the relay to the starter, or the starter itself.
There isn't much chance the wiring just suddenly died and no amount of tugging on it won't help, so I'm thinking starter.
  I noticed there are 3 different identical relays in the under hood box, so I swapped them and it made no difference.
Am I missing anything?
Use a meter and confirm 12 v for the primary wire and when trying to crank at the solenoid wire - at the starter. Then use a small jumper wire to put voltage on the solenoid from the primary wire.
Wife's ride.
Jump terminal 30 to terminal 87 of the starter relay using a piece of wire. This will engage the starter.
Or, you can do it the right way and test the purple wire on the starter using a test light. If when cranked the test light illuminates, you know you have power going to the starter and the starter is the problem.
It started up the next morning.  So no diag is possible yet.
I may just take a guess at the starter.  The relay clicked when you turn the key, so that tells me everything from the key cylinder to the relay is fine.
So unless the wiring suddenly went bad with no warning from the relay to the starter, it's the starter.   Not sure I'm willing to risk having her stranded again when that's almost certainly it.
Had a similar problem with 04 Sierra. Would crank 90% of the time then nothing. Went through bsttery, key cylinder, ignition module, relay etc, etc, etc. Eventually replaced the starter. Works. Concluded that part of the wiring in the starter had gone bad so if bad sections line up with the brushes - dead.
Sort of what I was thinking.   Since the relay energizes when you turn the key, that eliminates everything from the key to the relay.  I eliminated the relay by swapping it with one of the other identical ones in the box.  So it's from there to the starter, and I didn't think the actual wire itself would just "go bad" without at least a symptom or two first.
Got a starter ordered, be here tomorrow.  Not looking forward to that job.
  • 3 weeks later...
Did this solve your issue, replacing the starter? I am having a similar issue with my 2009 GMC Yukon XL 5.3L.  Link: https://www.gm-trucks.com/forums/topic/221199-2009-gmx-yukon-xl-slt-starting-issues/
Come on starters aren't that bad unless.... you have oil leaks everywhere. I'm sure by now you've realized it wasn't that bad though. Did this solve your issue is more of what I've been wondering.
Had a similar issue with a 2000 Ford 4 cylinder 2.5 and it turned out to be the #3 piston cracked. Had stopped truck from running so even with power at the proper terminals I used the proper socket up front and manually made sure the motor would turn but you didn't mention a grinding noise before all this happened as the owner of the pickup said the engine made a clunk or grind noise as he couldn't recall. I myself thought it was his psychosis because of all the weed he smokes daily. Wasn't to bright just out driving around in -20 weather with -45 wind chills that night and thought I'd come get him by calling me which I didn't as it was 25 min from home at a minimum not counting warming the vehicle up and I don't have a tow truckm
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
