Sport Bar Lighting, Wiring & Switching
I have a Go Rhino sport bar in transit,  I believe I will be purchasing (5) Q Series LED pod lights from Rigid Industries. I'd love to see how others have ran their conductors for power, fuses, disconnects,  and cab / interior switch setups. Any and all pictures , and information are greatly appreciated. Youtube and forum searches have been mostly a bust. Interested in what lights you all are running?
2016 Silverado Z71 LT Crew Cab
These aren’t specific to your instal, but are general aux light installs.
This seems to be a popular option on this site;
https://www.gm-trucks.com/forums/topic/214990-oem-off-road-light-switch-install/
I found this one  and it appears to bypass the BCM, and likely the problems some of those with pre 16’ had;
https://offhighwayequipment.com/silverado-sierra/silverado-sierra-1500-2500-3500-2014-2018-auxiliary-light-switch-kit-single-channel-with-fog-lights/
I've added tons of lights to my truck.  Started with adding 2 12" combo beam light bars on the GM sports bar.  These lights are absolute cannons.  Each light pulls 72W
I was super impressed with the lights but there was a big shadow in front of the truck because the cab gets in the way.  So I added the rough country bull bar that has there 20" single row LED bar integrated.  This single light bar is flood optic and draws 90W worth of power.
This now provides a solid wall of light in front of the truck but still decided to add a pair of ditch lights for more side lighting.  This was a very cheap mod.  I got the pair of lights for 25$ and the hood mount brackets where 12$ for the pair.  Each light pod pulls 12W of power but has a very unique optic that makes a very wide beam of light.
Had some leftover leds laying around so I put them in the wheel wells.
All the exterior lights are wired up to the factory upfitter switch.  Mounted the relays to the firewall behind the battery.  all the wiring is in plastic conduit and follows the factory harnesses.  I made one of the aux switches work as a master switch that turns on all the lights with the high beams.
Also threw some RGB leds under the dash and rear seats.  The controller for the lights are pull power from the driverside fuse panel and the colour/brightness are controlled with a RF remote.
I did not even think about the factory "upfitter switch" location where the Traction Control switch is. I'd been contemplating housing them in the center console by the 12volt plug and usb devices. Do you mind referencing where you managed to locate those "Aux" labeled auxiliary switches? Did you run loom through your bed rails continuous , under the body with existing harness,  then up to the firewall, or is there something more rigid to protect the conductors? Beautiful build , appreciate the photos and input.
Awesome option,  I'm going to research pricing on that switch. May run that as a master override / relay for all added exterior lighting,  then run Aux paddle switches like Crazyjoker77 for each location/ style to be individually controlled. Both are much more aesthetically pleasing than my initial thoughts. Thank you very much.
Does anyone have specific names or links that could be provided to either switch options mentioned above? If I locate them I will also post them here for future. New to this forum, do they often archive here? Do all threads remain in place or do they get cleared often?
Realized the OEM next to fog offroad light, dial switch part information is in the video at the start of the thread.
GM - 23458495 (2016 Red backlight)
GM - 84168423 (2017 Blue backlight)
A suggestion: if you wire the OEM switch to the BCM there is a time period you must wait (5 or so secs) between turning lights on to turning the lights off, but if you go with the extra console option in the 2nd post I *think* it will be immediate. The good with the BCM option is it will light up the off road lights activated light on the dash (next to high beams). I plan on wiring to BCM and using the wire to power multiple relays for multiple forward lights. You can also place those lights on individual switches which only power on when the BCM light switch is activated, just extra wiring/switches. I found this custom 3 switch panel, it’s engraved for nitro but I’m sure there is a way to change it;
https://www.nitrousexpress.com/15789-2014-up-silverado-custom-switch-panel.html
Watch this video for the OEM switch info.
https://youtu.be/4fESc7THdsQ
Big thanks to Tinkering Fox for making this extremely informative video about buying the correct OEM switch and installing it!
I bought the custom wiring harness from Pgamboa, $35.
part number for the switch that I used is 23145158 and was 61.69cad.
If you want a full factory upfitter switch setup its going to have to buy a lot more parts than just the switch.  Basically all new harnesses and a under hood fuse box as most of the trucks don't have the right one.  Its simple enough to get the switches to work with some standard automotive relays though which is the route I took.
The factory wires don't go into the frame rails they're just beside them on the drivers side.  So i just followed them and zip tied along the way.  The factory uses that plastic split loom so that's all I used.
To get through the firewall I again went through the same place the factory did which is on the drivers side and has a big rubber boot.  Take the harness tape off and shove a coat hanger alongside the factory loom.  Then inside I unbolted the 3 bolts on the big black junction in the drivers side food well and flop it off to the side to give me some room to tape the wires to the end of the coat hanger.
I like that NX option as well, I do have the towing / brake assist options in that location on mine sadly. I agree that the OEM through BCM switch (even with the wait duration) is the most aesthetically pleasing.  I thoroughly enjoy that is has a dash indicator as well. Im most likely going that route to get everything (5 pod lights) started and run by just that switch,  until I locate those AUX paddle switches and have them control the differing sets (2 outer pods being Diffused controlled together,  and 3 inner being Floods tied together). I'd love to set a couple slim diffused rear facing hanging under the sport bar , on either side of the third brake light, as better scene / reverse/ cargo lights not controlled by the oem master, but on an auxiliary. Time and money will tell, same goes for how this Go Rhino bar is configured. Thank you
I'm very new here and have seen Pgamboa's name many times already,  particularly in the LTZ headlight and taillight areas. Seems like an awesome individual. I'm an electrician by trade, but honestly love supporting those that make a great product,  are outstanding to the community,  and make my life and installation easier. Lol
Perfect,  great information. It's been a busy weekend and week already and I haven't had a chance to get under it yet to view my route. As for the bed / sport bar area, are most running between cab and bed? Without getting underneath (and very recently purchasing my vehicle,  not being very familiar,  and never working with trucks but small coupes) I was thinking I may have to run all the way to the rear of the bed, come up where the tail light harness ends, then run up under the bed railing back to the sport bar to keep it concealed,  not exposed to physical damage.
On a dumb side note, are you aware of anyone drilling drain holes in the bed , close to the cab? I park on a steep driveway and it often pools water.
Again I followed the factory harness (went to my integrated 3rd brake light in the sports bar).  The factory harness goes through the front left stake hole and comes out under the truck.  I pulled the wire from the lights down into the sports bar then through the stake hole to the underside of the truck then followed the factory harness to the engine bay.   It was a bit of a pain feeding the wire down the stake hole as there are lots of lips and the gas filler tube in the way.  Probably would of went easier if I did jack the truck up or had a second set of hands to help fish it down.  It would be even more difficult trying to get the wires from the underside up to the stake hole.
I've got the factory spray in bed-liner so I don't really care if the water pools.
Got it, again more awesome information. Now I just need to order some loom , and the oem switch. With ath in mind, van set everything in motion once everything arrives. Thank you everyone for all the very useful knowledge.
What lights did you use for the interior ? I was thinking of doing something like that conected to the dash lights so it can dim and also put a switch in between for when I want them off altogether .
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
