Curious On this .
These “Catback” exhaust systems are just that, from the cat back replaced.
why pay all that money to replace GMs OEM piping which is already stainless!
The only gains you Get are from the muffler swap , taking the old muffler out with the flappers and replacing with a high flow muffler no flappers.
essentially that 13 HP gain for $2000 dollars can be had for around 200-300 dollars.
save your money people, replace the muffler you will get the same gains and sound or better lol.
as far as a cold air intake , get S&B , Volant or Cold Air Inductions. They make much better design intakes and filters. Disconnect the negative battery terminal during installation. This resets the ECM so it can re learn the fuel trims .
No need to get GMs “Tune” . Its not a tune.
Edited by Chips
39 minutes ago, Chips said:
Curious On this .
As of a couple months ago, the only emissions legal CAI was the GMPP.  Also, the GMPP exhaust does not cause any drone.  If you just get a muffler you'll may well get a drone.  You'll just have to research and try things.  All the reflash does is turn off the air filter minder.
If you wind up with any rewards or discounts, you can beat $2k installed.  Even if you can't, the difference between $300 and $2000 over a 100,000 miles isn't significant.  At all in how much time and desire you have to fuss with stuff.
Emissions legal? Must be talking Cali.
Anyway just thought it should be brought up you can buy just the muffler from borla and still get no drone and effectively accomplish the same thing.
A cat back exhaust system on these trucks wont produce much if any more than a muffler swap/ flapper delete.
Not in CA and I will never live there.  Many states now follow CARB emissions standards, but there are federal emissions standards that all vehicles have to meet and as if a couple of months ago, none of the CAIs for the 2020 6.2 were legal.
No doubt the muffler is the big issue, but when buying the GMPP/Borla, you are also paying for the testing and engineering that went into eliminating the drone and minimizing the helicopter sound.  That makes it worth the cost to many of us.  For those wanting to spend as little as possible, they will have to do their own research and testing.
Neither choice is wrong, but people do need to be aware.......
Edited by INTJ
7 hours ago, INTJ said:
Not is CA and I will never live there.  Many states now follow CARB emissions standards, but there are federal emissions standards that all vehicles have to meet and as if a couple of months ago, none of the CAIs for the 2020 6.2 were legal.
Edited by Tcolburntexas
  • 4 months later...
Just swapping in a Borla muffler will lead to drone.  If you do some more custom work or keep 1 or both flappers in you very well could reduce/stop the drone all together.
Don't get me wrong, I went with a custom setup myself and the GM performance exhaust is a joke IMO and not worth the money, but it does have minimal drone but it also adds next to no sound, so really what was the point?
I don't know what GM Performance exhaust you heard, but it is not a "joke", very well-built, and DEFINITELY adds sound over stock.
I said imo, and that is fine its built good and has some sound, barely, over the stock setup.  But I don't buy exhaust systems purely for sound, that is a component but not the entire reason.  If you want sound and that is your goal, do a muffler swap.  I've put on or had made many exhaust setups over the years, some are worth their price tag, Corsa and corvette come to mind, where others are not.  Is the GM exhaust worth the price tag? nope, but like I said that is my opinion.
Edited by 204Denali
Should probably turn your hearing aids up.
Good one.  Defensive much.  Its not loud, sorry that hurts your feelings
  • Haha 1
Why do you feel it is not worth the price tag?  It is not cheap but the exhaust with the CAI offer fully factory engineered and backed parts, K&N filter, better sound, better flow and a new factory tune tying it all together.  It makes a legitimate 15 hp and 9 ft.lbs. of torque over stock set up (link:  https://www.gmc.com/gmc-life/trucks/sierra-at4-off-road-performance-package)
 - so unless you want more sound - what is not to like, other than maybe the OEM pricing!   Fully engineered OEM system that makes real power - that is a good combination in my book.  I have it on my 6.2L AT4 and find the total package a pretty good deal.
Mine didn't come with a K&N filter.
I could be wrong, but my buddy works at K&N and he told me they make the filter for GM, just like the K&N filter in my 2015 Z/28.
I don't see the value in it.  If we were talking the Corsa setup then I might agree.  Like I said I  am all about aftermarket setups if I see the benefit, all my summer cars have full setups from the headers back, Corsa on the Vette, Magnaflow on the Roush, but the GM perf exhaust I do not see the setup matching the price tag.  The muffler is basically the XR, which imo is not loud enough.  It just doesn't make enough sound for me.  Your basically paying the GM tax for the setup.  I put a custom mandrel bent setup on mine instead.
Your also taking the catback and combining it with the CAI for the numbers, which I'm not denying they are there, but not many are buying both. I also think the GM CAI is overpriced as well, plenty of other choices out there that cost less and look better, and put up good numbers.  I'm not after numbers, if that was what I  was looking for I'd be looking into heavy engine mods.  If I want to go fast, I pull out my car (when its not winter lol)
Edited by 204Denali
    RyGuy43
    RyGuy43
  • Who's Online   0 Members, 0 Anonymous, 469 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
