Started out earlier this week with the truck thinking the driver's door was always open and the window switches in the driver's door not working. I pulled the door panel off, checked all the connections but I didn't find anything obviously wrong. Now that I have put it all back together, the truck thinks the door is always closed and the window switches in the driver's door still don't work. The radio does not turn off and the dome lights do not come on when the driver's door is open. The locks and mirrors work as they should. Any ideas where to start or what to test?
You probably need to replace the driver's side window switch. It communicates with the BCM to control both the windows and the door open switch; I don't know if it does the locks.
I wiggled the harness and door jam connector around but nothing changed. But now I've opened and closed the door a few times and its back to thinking the door is always open
i remember reading that there are issues with the door harness chafing.  id think to pull the panel again and go over all wires and look for fraying.
Un plug the connection and to can use a digital multimeter and set it to fuse test. It will make going wire for wire much faster. I pulled mine all the way into the large speaker hole to get new wires feed through.
I pulled the door jam connector though the speaker hole last night and found the LIN signal wire (green/yellow) completely broken. The large black (ground?) and red/blue (power?) wire had broken insulation as well. I patched them all up and everything seems good now. I'll probably just replace the harness at some point. The hard turn the harness makes to go into the door seems like a really obvious problem point that should have been addressed a long time ago.
Door passthrough wiring is always a problem aria.. The wires move every time the door does.. I  was going to suggest you look there, but you found it yourself.. Nice work!
Question, tryna figure out why passenger door power step don't come out, could it be a door ajar issue, I got a 2015 Silverado LT  5.3l. I got no open door chimes or indicator on my lcd screen
  • 9 months later...
Hey were you able to fix this problem and if so what was it? My 2015 Silverado LTZ is doing the exact same thing. At the moment the door doesn't read that it opens, the dome light doesn't turn on when I open the door, the radio stays on, the driver side window doesn't roll down. Sometimes when it does work the DOOR ADJAR would stay on all the time even when the door was closed and the driver window sometimes rolled down and back up. I would wiggle the wires at the door (when door is wide open) that lead into the cab and then it would roll all the way up. As of now, the door doesn't read at all, driver side window doesn't roll down (but the switch rolls down all other windows), radio stays on... any tips?
  • 4 months later...
i am having that very exact issue
2017 Sierra 3500 Denali HD
anyone?
  • 9 months later...
I'm having same issue..2016 Sierra 1500. Door ajar always showing, master switch doesn't work for windows but locks and mirrors work. So I exchanged switch for new one, nope.  Disconnected plug to motor and have constant 12v to top left of plug but not top right. I tested connectivity to motor (from the 2 prongs in plug receiver and nothing. I ran direct power to the motor by 12v battery to the 2 prongs and nothing. Suggestions?
Hey, were you able to fix this problem, and if so what was it? My 2015 Silverado LTZ is doing the exact same thing. At the moment the door doesn't read that it opens, the dome light doesn't turn on when I open the door, the radio stays on, and the driver-side window doesn't roll down. Sometimes when it does work the DOOR ADJAR would stay on all the time even when the door was closed and the driver window sometimes rolled down and back up. I would wiggle the wires at the door (when the door is wide open) that lead into the cab and then it would roll all the way up. As of now, the door doesn't read at all, the driver-side window doesn't roll down (but the switch rolls down all other windows), radio stays on... any tips?
My truck is having this same issue.  I was looking for a answer to Carlos Plata's question and did not see one.  Did you find out what the problem was?
I did not fix my issue.  I still have the truck and drive it almost daily.
My door ajar issue got very sporadic and intermittent.  I’m thinking it’s a wiring issue because it really went bananas after a couple of rainy days.  Then when all the rain stopped, so did the intermittent issue.  So now I believe whatever the problem is, it is outside.
Then, it failed completely and luckily it failed in my favour with the door closed and window up.  So the truck thinks the door is permanently closed.  Now although that door doesn’t register when it is opened… I don’t have to deal with all the dash dinging and all the lights/door ajar warnings.
Whatever the failure is I’m suspecting it’s one common location with all of our trucks.
 The other commonality is, whatever is causing the door issue is linked to the windows, because although my door shows as closed, that window no longer works.  I tested the window motor and switch, they’re both good!
so to summarize, whatever the issue is, my theory is that it is outside and common between the door and window.
So what did you find when you checked the wiring? Were there any broken or chafed wires where wiring passes out the door to the connector?
Edited by mikeyk101
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
