So I noticed my AT4 has two valves one before the muffler and one after the muffler. Has anybody clamped them open as it was done in the previous gen?
Just looking into getting a bit more sound. I went under the truck and held one open but didnt notice much difference. Today I stumbled upon a youtube video and noticed their was two valves. I guess I can give it a go this weekend; basically just wondering if its been done and if you are happy with the results.
Yes, i removed both valves. They each have a 1.25" restriction. The aftermarket GM (Borla) exhaust eliminates the valves. I cut both mine off and installed a Magnaflow 12909 and gave it the sound and performance it should have.  attached is a picture of the valve in the open position.
Interesting to know. I was under the impression that the halve would open fully.
If that half round section wasn't part of the valve, it would be fine, however, i'm sure it's part of the reason its sounds the way it does.
This is interesting. I wonder if the back pressure somehow creates more horse power?
Back pressure assists with the cats working properly but does not help performance
Sent from my SM-G975U1 using Tapatalk
I found this which would be easy to install but the price is just too exaggerated I think; plus the valves would still remain in place as it does not state that it's long enough to cut them off. Perhaps I am wrong.
Edited by asalinasz39
The GM exhaust kit does away with the flappers, there is no reason to keep them. It's cheaper and more effective to just cut the flappers off and install a Magnaflow or similar muffler and be done. A muffler shop can do it all in less than an hour. It's easy stuff for them.
The GM aftermarket cat back system does not use the flapper valves. That tells me they don't aid in horsepower, rather they restrict it.
So I am looking at this muffler Borla XR-1 Racing Mufflers 40085 or the carven r which I loved on my 2016.  WHen they put in aftermarket muffler what do I tell muffler shop to do eliminate the flapper valves or do they get eliminated when you put in aftermarket exhaust.  SOrry if this is a stupid question just want to give shop the right directions.
Totally makes sense to me guys! Thanks! I will temporary clamp the valves open and see what it sounds like until I have a chance to head out to the muffler shop and cut them off followed by a replacement muffler.
You should tell them to eliminate them just to make sure they do and get your full performance and sound desired.
That won't help much.; They have a 1.25" restriction (as per the photo above) when open. Best to cut them off.
Not a stupid question at all. When they install the aftermarket muffler they can either cut off the valve and hand it to you so it can be reinstalled later if need be, or they can leave it. They are located behind and in front of the OE muffler (if you have a 6.2). I doubt there would be much of a performance difference if you leave them, however it will be quieter due to the restriction. I say cut them off, weld on the new muffler, give it a chance to break in and see if you like it. If it's too much, they can weld one back in. If it's still too much, weld in the other one. I would leave the resonators, they are straight through and don't offer any performance advantage if you cut them off.
So i was under the impression that my AT4 had 2 valves however looking under the truck mine only has 1. I had seend a youtube video earlier with a 6.2 At4 and that must of thrown me off. My 5.3 only has 1 valve.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
    • I read through that and I won't lie, my eyes rolled at some of the quirks about how it can turn off the trailer braking for example but I can see how it could help control or even up the torque applied to the ground with each wheel in a boat ramp scenario. But of course what it can't do is increase the torque to the wheels if the need is there as it ends up being like driving the four wheel drive version of a two wheel drive ( high range that is ). So far the neighbor that ended up with the 3.0 duramax with the max tow package which meant the 3.73 gears and high range only, I think its been doing ok for what he has been towing but doubt he ventures off into the soft stuff with his holiday trailer. He may have towed his dads river boat locally with it ( he always used his 6.6 duramax before ), I'll have to ask him sometime if he got into a lack of power to the wheels situation as after all that engine produces a lot of torque at low speed once the turbo winds out a bit and I think it has the 10 speed and if so they have a pretty good first gear ratio at 4.70 I see which is vastly better than the 3 or four speed overdrive models of years ago.
