2014 SLT doesn’t have SLT headlights
I just purchased a 2014 GMC Sierra SLT Z71 that was made in 2013. I’ve been looking at the forums and people say the SLT’s came with different headlights than the other lower trim levels. Is my truck actually an SLT or did the early 2014 models not get the upgraded lights?
Those are correct lights for an SLT
Sent from my VS995 using Tapatalk
Not positive on the GMC's. but look for YE9 in your factory RPO codes in the glove box to confirm SLT.
Welcome to the site, neighbor to the south!
You have the correct SLT headlights.
You can see the DRL's (LED) strips above and below your Halogen Projector.
You’re correct, hated the crap halogens in my 14,16 but were switched out in late 2016 or early 2017 models with the upgraded hid headlights. My current 18 is a night and day difference literally
Sent from above
I had an early 2014 truck. Build date was October 2013. It had LED daytime running lights around the halogen projector. The DRL were great but the halogen sucked. I swapped for HID. Million times better.
Take a picture of the lights on. Hard to tell from this picture but those don't look like SLT headlights to me. Looks like your missing the LED DRL.
VIN or Carfax should identify your trim as well. Not sure if someone said that already.
Thanks,
Jon
Sent from above
16 to 18 K2 headlights are LED projector. Not HID...
You have SLT Head Lights that have the LED DRL with the Halogen Projectors.  Piss Poor factory lighting for a $50K truck.  My 2015 SLT had the same.  I did a HID upgrade right away by installing the Retrofit Source kit that runs around $180 or so.  It was much better but still not to my liking after coming out of a Denali that I had done a HID projector retrofit on.  So a few months later I did a complete projector retrofit with FX-R projectors and DS2 bulbs and could not be happier.  I also replaced the fogs with Morimoto XB LED Fog Lamps.  They both do a great job of lighting up the road and the sides.  As far as the headlamps you have to be willing to bake them open to perform the projector upgrade.  I used brackets from Fast Headlights.  At the time I did it, I purchased an extra set of headlamps in case anything went wrong with the retrofit or I had any warranty issues while the truck was still in that period.  Never had any issues so I sold my original set set of lights.  Lights are cheaper now than they were four years ago...
If you look in my gallery there are some pictures I posted long ago of the projector upgrade...
Good luck
The halogen headlights are horrible but the LED’s Rock!
Sent from above
4 hours ago, Sierra Jon said:
Sent from above
Not all of them were LED. There were HID and LED headlights available for the Sierra and Silverado.   16-18 Sierra with halogen front turn signal - HID, same with Silverado.
I'm talking about the K2 Sierra. Not aware of anything other than the intellibeam headlight with LED projector. Even the work trucks have them.
My 16 DMax LTZ Z71 wasn’t LED either.
Sent from above
Do you have an led strip on the top and bottom.
if you don’t, you don’t have slt headlights
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
