It sounds good on their YouTube.  If I go Flowmaster I think it'll be the American Thunder Series.. Although I'm currently leaning twords AFe
Dang it you had to mention Afe. I had not seen their exhaust. I had convinced myself I was just going to cut the flappers out and install a 3.5" muffler instead of buying a flipping $1k + catback. Now that I looked at the Afe with 4" in and dual 3" out for the 6.2 I might have to have it. I haven't found any clips on what is sounds like though. Afe has a clip of a 5.3 but I bet the 6.2 sounds a little different with the bigger pipes and muffler.
It sounds perfect on the 6.2, nice quiet rumble at idle, and aggressive when you get on it.
I bit the bullet and ordered the GM performance system. I just want something a bit louder in the low RPM and decent sounding when on the gas harder. The price sucks but I guess you pay for what you want.
Anyone know if the OEM dual exhaust can be taken off without cutting anything?
Consensus so far is it’s easy to do if on a lift but if on the ground it’s nearly impossible without cutting.
Edited by Limelight
Directions on the flowmaster tell you to cut right after the Cat. Other than that seems pretty straightforward. Installing it tonight.
Just got it on the truck and first impressions are good!
It's got a really deep throaty sound. I'm liking it a lot, throttle response seems better also. No noticeable drone either.
Edited by RSTPilot86
  • Like 5
Agree'd with RSTPilot. It's actually louder than I thought it would be. Funny that my wife had to take the truck today so I didn't even get to really test it out. She texted me though and said why is your truck so loud... haha. All in all took about hour and half to install and did it on the ground at stock height. I'm a decently skinny guy, it was a tight fit at some points lol.
Edited by drewbiehd
  • 3 months later...
looking at the same kit, wondering how it sounds at 75 in the cab.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
