10 hours ago, steelcity said:
Above are some trucks at the dealership. Bed is higher than the cab lines.
Yea looks about like mine.  Disappointing and the last time I buy a new vehicle sight unseen.
Hey guys I did it myself following a service bulletin from gm about bed alignment they had just loosen bed bolts there is 6 if I remember right 18mm socket then lift a little to fit a hand saw blade in between frame and bed and cut a plastic pin which is located on passenger side front of bed I grabbed mine by wheel wells and pulled over which ever side you need it to mine needed it to passenger side this is not for the height it was for left or right
https://static.nhtsa.gov/odi/tsbs/2019/MC-10169342-9999.pdf
    Paul Annabelle
    Paul Annabelle
  • Who's Online   4 Members, 0 Anonymous, 1,228 Guests (See full list)
