LT Trail Boss brake problems
Anyone notice their front brakes wearing out super fast? I have 6300 miles on my truck and it says they only have 56% life left. Replacing breaks every 15k miles? Seems crazy.
Yep. I have about 800 miles and I'm at 97%. At that rate I'll need new brakes at about 15k-20k. My brakes have always lasted me over 40k...
Sent from my Pixel 2 XL using Tapatalk
Seems to be a common problem among the owners. Mine are wearing fast according to the readout. The sensors and wear calculations might need to be updated. The techs have
inspected my pads and they are wearing fine for the mileage.
I'm thinking it's a software issue or a sensor issue too. I just can't imagine these brakes wearing as fast as the ready says especially since I've been babying it got the most part done I'm still in what I consider the break-in period...
Can you report back? Ask them specifically what the measurements are on those pads vs what they are new. Brand new pads probably measure around 15/32”.
The sensors are showing faster wear than it really is.  Best way is to check yourself when you tire is off for a rotation.
Dealership fed me a bunch of bullshit saying that driving habits are likely the cause. Told me thats “just how brakes wear” typically bullshit from Chevy.
1900 miles on my Trail Boss LT.  This morning fronts were at 69% and rears were 82%.  At this rate, the truck will tell me the brakes are worn out by 9,000 miles.  WTF?!?!
Hmm, wonder if you can remove the pad monitor from the dic? Sounds highly inaccurate or there wear out fast. Idk
28 minutes ago, BringTheRain403 said:
Yes you can turn it off. Whether it's accurate or not has yet to be seen
Custom TB here 3200 miles 5.3 front 97 rear 98%
My truck is in for some issues and I mentioned this to them. They weren’t even aware of the sensor. Really? They told me the same thing about driving habits. I called bs on them too. Said no way because I drive highway on cruise all the time. I’m at 3700 miles and 70%. They were baffled. I’m having brake issues as well like hard brake pedal with almost zero throw and creaking. I’m thinking my brake booster is defective as well. After test driving it with the tech Wednesday morning they said I should be done by end of day and will be getting a call. Well, it’s Friday night and still no call.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
    • Open the driver's door jamb.  What do the cold tire PSI ratings on the tire placard show?   I'm not saying to run it to those numbers, but I would like to know what it says.
