Should I Go Diesel?
I'm on the fence between buying a 2019 2500 Duramax vs. the 6.0.  Honestly, I don't need the 6.6 Duramax, but the price is under $60k for a Denali...just $59k and change.  Seems like a great deal.  There is the same truck available for about $6k less.  Even though I don't necessarily need the diesel, I wonder if I am money ahead in the long run buying it, in terms of resale value.
In case you're wondering, the reason I say I don't "need" the diesel is that I rarely tow, mainly I need the payload which is higher on gas trucks.
Curious what you guys think.
Depends how you drive. Long trips, diesel is better. Short trips, lots of stop and go, get the gas.
This pretty much hits the nail on the head.
The exception being if you prefer the way the diesel drives.
Some thing about how it 'pulls/accelerates' without fuss and without downshifting (usually) is different to the gassers.
Things changed around here (I need neither the payload nor tow rating of an HD) and I tried to give up the 6.6's, but wasn't happy with either of the v-8's in the 1500's, so I'm back with an HD and the 6.6.
You're very close to being able to get a 2020 with the new 6.6L gasser if that does anything for you.
LT8 -  Direct Injection and Variable Valve Timing, gasoline, (401 hp [299 kW] @ 5200 rpm, 464 lb-ft of torque [629 N-m] @ 4000 rpm)
It does indeed, and I thought about it, but I don't know that I want the first model year of that engine.  Plus the deals on the 2019 are pretty good right now, being the end of this model.  The 6.0 Vortec has been pretty much bullet proof.  A little under-powered yes, I've had two of them, so I know them pretty well.  But a damn solid engine.  I just am toying with the diesel given the relatively small price gap.
My only downfall with the diesel in the 2500 is payload loss. Have to move up to a 3500 to get payload back. Sometimes i wish i got the diesel but i hit a red light every 100 ft and my longest daily drive is about 10 miles. Not practical for my application.
Sent from my SM-G960U using Tapatalk
Depending on how long you keep it and how many miles you drive it's going to take you a long time to recoup the extra money spent for the diesel that you don't need.  That's just on fuel prices.  Then you have to include all the extra maintenance that the duramax needs vs the 6.0.  Filters, more oil, and def to name a few.  Plus if you keep it long enough for it to go out of warranty how much all the emissions garbage costs to repair/replace.  Even though you may get more for it when it comes time to sell, you probably already paid that difference in maintenance and fuel costs vs a gasser.  Having said that I DD a LMM so what do I know, I did inherit it so that's probably why.  I'm waiting to see what the new gasser is going to be like and if it'll be enough for me to give up my LMM for.
Solid points, thanks!
Pulled the trigger on a 2019 Sierra 2500 CC Denali 6.0.  Very happy, beautiful truck.  Now, do I level out the rake or not?  Decisions!!
Lift that bad boy.
Pics or it never happened.  Congrats on your alleged purchase!  I'll probably be the outlier but I always leave my pickups stock height.  To each their own.
Ditto. leave it alone. Drive it and have fun.
Thow that stuff in the garbage!  LOL
Maybe just level slightly? I cranked torsion bars for about 1" of lift - still has rake, just not quite as steep.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
