I thought i heard somewhere that there were multiple complaints from noises like this on cold start and it was the vacuum pump .
I did too but these new 19s dont have them.
Does it have a electric unit like the vettes then ?
Not sure if it's like the vettes but yes its electric. My brake pedal feels different everytime they update it.
My 2015 5.3L slowly started making a similar ticking sound. You could hear it immediately on start up and then it would slowly go away once the vehicle warmed up (10-15 mins). Took it into the dealership and they told me lifters and cam need replacing. Its currently under warranty for another 16 months thankfully. I am worried about what the future has in store for this motor. Getting a tune with AFM delete seems to be a beneficial option moving forward. I have to do more research... Only 69,000km and I am experiencing this. I drive my truck nice and easy like an old man too!
did you listen to the whole video?. My truck sounds fine the first 20ish seconds of startup. This noise starts after the RPMS drop to normal idle. I bought the truck with 150 miles on it and its been doing it since.
  • 1 month later...
2019 Custom Trail Boss 5.3 AFM  3125mi 99hrs. Same problem here, knock on cold start after high idle goes down to normal idle rpm. Not wasting time taking to dealer until there is a fix or it blows up. Very very disappointing.
I'm new to the forum here is a link to a video on google drive. https://drive.google.com/file/d/1-F78kbKOloomcOzkAYiSG5A98tQiijCP/view?usp=sharing
Sounds identical to mine. Just like mine, the noise will fade for a while after an oil change.
Are you just going to ride it out until there is a fix? I don't have much faith considering the bulletin has been out for almost a year. I don't think they plan on fixing it anytime soon.
These engines both the 6.2 and 5.3 sound like a box of rocks at idle imo, nothing new my 14 6.2 does the same thing. Personally i really don't want to allow a gm tech at a dealer to crack open my engine unless it is no doubt gone or in trouble! I will say while driving though she revs fine and sounds great in the upper rpm range.
Did you watch our videos? The loud rapping noise is what we are talking about.
Yes the random tapping noise is what you are talking about right?
My 14 6.2 has the same random occasional tap noise at idle.
Not to discount your concern. I’ve owned lots of small blocks. GMs seemed to be noisy. My latest of 8 years sounds like marbles rolling around in the top end. Get it serviced at your GM dealer and have them make a note of the noise each time. If it fails they should back you up.
Way different then ours. Have you watched the videos? it happens dozens of times after the RPS drop and lasts a few minutes. Its raps so loud I can hear it in my kitchen while my truck warms up.
I don't think we are talking about the same noise.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,320 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
