Hello,
Back in july I bought my 2019 GMC Sierra 1500 SLE, I have the same issue as you, its going in Tuesday for them to "look at it". But I can guarantee ill get the same run around. It is very disappointing thinking it was going to be a good truck since my 1995 Yukon 5.7 is going strong still.
On 10/25/2019 at 2:57 PM, ericgcsc said:
Hello,
Let us know how you make out. There have been a few people that actually got the dealer to replace the lifters but it didn't fix the noise.
  • 4 weeks later...
What's the latest updates from you all on this issue? Been about 3 weeks with no responses. Be interesting to see if anything's being done from a bleacher perspective as I only have a 04 Tahoe with a 4.8 that started doing it when cold but I just think mine is the exhaust manifold gasket getting worse. 3yrs and going with a broken drivers side rearmost bolt.
Sent from my SM-N975U1 using Tapatalk
The Issue we are referring to is listed in the bulletin as 2018, 2019 5.3, & 6.2L V8s.  But to answer your question GM has done nothing and it has become a legal matter that my attorney has advised me not to talk about on social media or at all really.
On 6/26/2019 at 1:23 PM, ct_corey said:
I leased this truck( with intentions to buy it at the end as long as it wasn't a turd). The current buyout from GM is around 39k. Trade in would be low 30s I would assume. I cant really afford a 10k hit right now.  My last 16 was a shaking turd. I should have learned my lesson but all other brands just don't do it for me. Should have bought a Toyota.
Best made tanks on the road, and Ive worked for Ford, Ram, GM and yota.
On 6/24/2019 at 4:39 PM, ct_corey said:
I am surprised no one has had this issue on here yet.  I guess if you just hop in a drive and don't listen to it warm up outside the truck people may not hear it.
Here's mine more of a tick brand new sierra,but only notice the sound if it's in the garage
That noise is normal most of these trucks do that. my 16 and my 19 do. My noise is more of a loud knocking for the first 10 mins of cold start up
  • 4 weeks later...
Had a similar tick from my 2019 Silverado RST with 2.7L 4 cyl. with 8 speed transmission. Noise as the engine came off cold idle. Then it progressed to ticking while accelerating from a stop. First the dealer said lifters, then said the flex plate (flywheel) was bad. Replaced it but noise was still there. Spent 3 weeks working with a factory tech, even reprogramming the computer. With no luck. Then the transmission tech noticed the service bulletin for the flex plate (19-NA-154) also mentioned the starter. When he pulled it he could hear loose parts rattling around. Replaced it and all is quiet, so far. And it only took 8 weeks to realize the starter was bad.
Edited by KR Smith
Spelling
  • 8 months later...
Mine makes the exact noise but quieter. Very strange and definitely not normal. I have 10k miles on my truck and just noticed it a few weeks ago as the mornings got colder. Based on my experience working on engines, this sounds dangerously close to light rod knock and/or piston slap. Disappoints me that I spent 40k on a truck that has this issue without even owning it for a year. Will definitely take it in to get it looked at and hopefully fixed ASAP under warranty. I would encourage anyone else with this issue to do the same immediately to bring this to GMs attention and at the very least have it on paper that your truck has this issue.
There is no fix for it. If the knocking noise goes away after 10 minutes of idling GM wont do anything. At about 12k miles my truck started to idle noticeably rougher(felt like a misfire). Again Gm wouldn't do anything to fix it. I ended up lemon lawing the truck. Gm was THE worse company I have ever dealt with. Get rid of it while you can if your motor sounds anything like mine. Its just going to get worse.
If you need a good lemon lawyer in CT shoot me a PM. I'm also a fellow motocross rider!
Very disappointing. iv owned 3 other Silverados before this one, all had well over 200k and were still running great. Really crappy situation because I really like the truck. I'm going to bring it in to the dealership to have them look at it and see what they say, but chances are they'll tell me to wait for GM to come out with a fix, which they wont, itll blow right when my warranty expires and then they'll be happy to fix it. I should've just bought a new Tacoma?
Naah.  Tundra.  Tundra's are not as boring as the Tacomas.. but like all Crapotas, they are still boring..
Boring but bulletproof and reliable so you can actually enjoy life.  Plus the Toyotas have the highest resale value on the market.
GM truck owners are going to be left with a giant money pit once the warranty expires.
Edited by 1997SierraSLT
Bulletproof?  No.  They have their issues.   Plenty of disappointed crapota owners out there. I'm one of them.  But they certainly have a better reputation than any of the others out there, that's true.
Edited by Colossus
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,189 Guests (See full list)
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
