On 8/21/2020 at 11:15 PM, Htown T1 said:
22x10 Fuel Blitz -18 offset
35x12.5x22 Nitto Ridge Grapplers
Sweet ride, what lift are you running?
What width of a 20 inch wheel and what brand/model? Your offset will depend a lot upon that. Im running a 20x9 Fuel Rage with a +1 offset running a 295/60/20 which is a 34x11.5 tire. Running a 20x10 will be different. A 20x9 with a +12 offset seems a bit pushed inside (positive pushes the wheel closer inward) but the backspacing may play a factor here with the wheel design. A 285/55/20 should fit a stock GM 20 inch wheel so what you are asking for should work in theory.
Thanks man! I am running the Ready Lift SST 4” kit (69-3940)
Nitto Ridge Grappler 295 70 18.  No level kit (yet).  Absolutely no rubbing or trimming necessary.
Welcome - Look's Good - How the ride ?? Does it fit in the garage ??
Edited by slj2008
Thanks. Rides great.  No real difference than the Wrangler stock tires.  It fits in my garage (standard door height) with less than 2 inches to spare.
Fuel Saber 20x9 +20 offset with Toyo Ooen country a/t II 275/65/20.
Did you use a spacer? Or did it clear caliper just fine?
They cleared the caliper just fine. 2 -3mm to spare
Niceee. My friend is picking these up for a Chevy 2020 Custom. I appreciate the reply
285/65 20 on stock rims no rub has about a 1/2 inch of clearance on inner wheel well
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 451 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
