Forgot to update. Ran into a deal that I couldn't pass up. Guess I'll have a summer and spring set
New setup (top)
Fuel Seige D706 20x9 +1mm  275/65/r20 Ko2
Old setup (bottom)
Fuel Vapor D569 20x9 +2mm 275/65r20 Wildpeak ATW3
I don't understand everyone's obsession with Fuel wheels. They're ugly and expensive. I HATE the massive center caps on them so they can sell them as dual bolt patterns to save money.
Is anyone running 305/70R18 with a +1 offset and 5 inch backspace on there setup. I am currently running the stock set up on my 2020 silverado 1500 6.2 Ltz with bilstein 5100 front struts set to max setting got about a 2 inch lift overall set at the max. I was squating in the back so I added a 2 inch block and bilstein shocks in rear. Want to upgrade my wheels and tires now just not sure how big I can go I am willing to to cut some plastic and remove the mud flap bracket but don't want to have to take the crash bar out just yet maybe in the future. I also tow a 8500 lb camper trailer a few times a year I will be getting air bags soon for that.
70614737286__F3352034-6DF6-411D-9D17-2A05CDD7F5AC.thumb.jpeg.c4c9d3d0f4f01b840cf0b2df21e50992.jpegMickey Thompson Baja Boss A/T 305/55R20 (33.4x12.3). Western Edge Gloss black, milled accents, 20x12, -44 offset. I have a set of 5.
These tires do not rub with stock trail boss suspension (removed blocks in the rear), and I’m running the Bilstein B8 5100 trail boss struts up front, regular Silverado shocks in the rear. Rides really nice.
The tires poke out 2” past a 2” flare. It was either fender lights or flares with more than 3” of protrusion, so thanks, Virginia, I’m running a fender flare instead of a light, because this truck is not a 2500.
Edited by s10dragracer888
i'm in the market to get new tires for my 2020 LT TB since my original tires are making a TON OF NOISE. i'm looking at the mickey thompsons. are these tires quieter than the wranglers? i want an aggressive look with less road noise than the oem tires. thanks.
Much quieter. I had the 18” Goodyears and they started screaming at 25,000 miles. I’ve put 20,000 on my mickeys and they haven’t worn much, if at all. They’re load range F (12 ply), and I run about 42-44 psi in them.
The M/T Baja Boss A/Ts are a tad bit more expensive than the Falken Wildpeak AT3Ws and the BF Goodrich KO2s, but I’ve had all three. I loved my Falkens, but these Mickey’s are my favorite. KO2’s wear out too fast and cup real easy
i pulled the trigger on the Baja Boss A/Ts since my local AAA shop matched the ebay/discount tire 20% that's currently running. i get them put on early next week. looking forward to the 'quieter' ride.
2019 LT TB. I’ll be riding stock suspension. Read through a lot of the thread here and it seems like I’ll be good with a 18x9 +18 Moto Metal Mo970 and 33x12.50 Ko2s, right? No rub? And if it’s on the flap I’ll just cut some.
2023 RST Z71. 2/4 Maxtrac Lowering Kit
24x10 +25 Escalade Platinum Oversized Stocks with 285.40.24 Toyo Proxes ST III. No rubbing, comfy ride.
On 3/25/2023 at 12:08 PM, 85CJ said:
Cooper Discoverer Rugged Trek - 275/60/2012EDAE92-7020-4C85-A279-7A16F534CF6B.thumb.jpeg.9cd4df34edd447e8962e7f530464c2b4.jpeg01A2D340-7F74-4010-9C64-4FEB9AED72BD.thumb.jpeg.23e35271d813b2067dac8f263dbfa0d7.jpeg
considering these tires for myself.  notice any decrease in power or mileage with your duramax?  thats what i have also so just curious
New setup (top)
Old setup (bottom)
Rims:
Fuel ammo bronze 18×9 +1 offset
Tire:
Nitto terra grappler g2 295/70R18
Bilstein 5100 front struts set at max height and Bilstein 5100 shocks in rear with 2 inch block. About a inch and quarter rake in the rear. No rubbing I cut the mud flaps and removed the mud flap bracket behind wheel liner and pinched the wheel liner back with self tapper to the crash bar.
Edited by Midnight Blue 20 Silverado
How are you liking these?  Loud? Smooth?
    1981dustin
    1981dustin
  • Who's Online   3 Members, 0 Anonymous, 1,574 Guests (See full list)
