I own a 2019 AT4, loaded.  I’ve had it for two weeks, been on vacation so it literally has 400km on it.  I go to leave my house and the gear shifter will not allow me to shift it out of park.  I stopped and started the truck a bunch of times and after about 10 minutes everything went normal and I was able to shift into reverse and leave.  The next day I went to run a few errands, everything was fine, then in a parking lot same thing happened only this time it never fixed itself eventually and I had to get my brand new truck towed to a dealership.  Anybody ever run into this before?  Pretty frustrating considering it hasn’t even gone through an entire tank of gas yet and I’ve had to tow it to the shop. ...
  • Replies 61
Top Posters In This Topic
I know that a few people have talked about this, from what i remember it should only happen when you use the phone to start the vehicle and it will never happen when you use the key fob.
Also, i believe that it is a TSB but i'm not sure if there is a fix yet.
Hmmm strange.  Mine did it no matter which way I started it.  The dealership is flying in an entirely new steering column and replacing it all.
They ran tests and found it wasn’t anything electrical or transmission related..
Mine is currently at the dealer getting a new column.  The shifter would not go completely into park, not allowing the doors to unlock or the vehicle to start back up.  They say a loose bolt has wallered out the threads and the column has to be replaced.  Only 11k miles.
  • 4 months later...
2019 AT4 owner here. 4500 KMs and started acting like that recently. Acts up at random places, gas station once, picking up someone, a friend who wanted to check it out. Really embarrassing.
Dealer told me to bring it on Jan 16 2020. So far not impressed. Just came from RAM too.
I just bought a fully loaded AT4 3 weeks ago and the same thing is happening to me too. First time in a GM vehicle and not impressed at all! After spending close to 60k I expected a great product and so far I would’ve been better off staying in my 2013 Jeep.
On 7/31/2019 at 9:01 PM, Sheldon Da Costa said:
The dealership started it up today and everything worked normal again.  They compared the shifter in mine too other AT4’s on the lot and said mine feels very stiff compared to the rest.
What was the outcome?
Buddies RST does it. Man does it piss him off. His has done it a dozen times. He doesn’t have the phone app at all.
Just bought a 2020 gmc 2500 one week ago. 3 times now its failed to shift out of park without turning it off then restarting. Often have keep pumping the brake before it'll let go. Took to dealer on 1/6 and of course they couldnt find anything wrong. Happened again today. I don't know what to do at this point.
Myself and my assistant chief are experiencing this issue. I have a 2020 AT4 and he has a 2020 ALT. Haven't found a solution yet. Sometimes I'll pull the truck into the garage and put it into park and the shifter immediately gets stuck. 99 percent of the time the truck gets stuck when starting her up.
Edited by FknLeon
The solution was found already by the OP, it's a bad column and of course like the window problem GM rather upset their customers and #@#@ them around instead of fixing the obvious problem!
Am I supposed to just walk into my dealership and demand a new steering column? lol
I've had my truck 3 months and have 600 miles on it.
Why not give it a try, it's obvious the column is bad and if you were out of warranty your dealer would no doubt very much come to that conclusion right before handing you a 1-2k bill for the repair. Dealers have no troubles throwing parts at a no longer under warranty car. If anything at least with this one they are not trying to literally use tape or sealant to fix their design flaws.
    tararebecca
    tararebecca
  • Who's Online   4 Members, 0 Anonymous, 626 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
