I bought Eibach’s and I am very pleased.
Good to know. I'm assuming worlds difference over the stock ranchos on the z71?
I'd be in for a set if they can be used with the stock height/stance.  I've hit dips along the interstate (not even true potholes) that felt like I lost a kidney.  I understand stiff suspension for towing but the factory shocks are not absorbing much.  How difficult is it to do the fronts?
For the install? I would guess not horrible if you have some insight mechanically. That and renting a spray compressor. Dropping the lower control arm, sway bar endlinks and you should have enough room. At least from the looks of it when I did my level.
I bought all 4 shocks for $435 and my mechanic charged $200. I got tired of waiting on the 4600 as I never wanted the 5100. Bilstein told me the 4600 is the best shock for stock height and for towing. I set the Eibach’s on stock height and it worked out great. Same height as stock and I only have 1/4” rake on my truck. The Eibach’s killed the chevy hop in the rear end and the truck drives much more planted.
16 hours ago, jbr1888 said:
Would these work? https://www.4wheelparts.com/p/bilstein-b8-5100-series-shock-absorber-33-253237/_/R-BBGL-33-253237
They are a hair shorter than the ones for the Trailboss. I have a 2 inch front level and a 1 inch rear lift block.
Not sure if this applies to your vehicle but I had my 2" rear blocks removed on my AT4 to get a more leveled look to avoid altering the front end.  After driving it around for a week I could definitely feel a difference in the way the rear end handled small and large bumps.  The smooth road handling had disappeared.  Since the stock OEM Rancho rear shocks were made for the 2" lift I looked for a non AT4/TrailBoss shock replacement with zero lift and went with the Bilstein 5100 which are good for 0-1" lift.  Truck now drives better than stock - on and off-road.  Very happy with the shock overall.
Where'd you buy them from??? Any wait time?
A local shop near me - SoCal Auto Style - ordered them and installed them.
On 1/10/2020 at 9:26 AM, vancealot29 said:
All,
I reached out to Bilstein for an updated date now that we are into the new year.  Their response.....
"We are estimating by the end of 2nd quarter"
And the wait continues........
Reached back out to Bilstein again this week.  Now looking at September/October per their rep.
Damn near two years in the new model......these things better wipe my ass after I install them ???
  • Haha 1
Damn....I'm trying to avoid dealing with the custom shops around here because the only one who would I don't trust sadly haha. I guess I'm waiting until they're officially released.
Damn near two years in the new model......these things better wipe my ass after I install them [emoji23][emoji23][emoji23]
Jeeez...I guess I'll buy them over the winter and install for spring time.
Ya - did not inquire about the front replacements.  The rears were in stock and installed next day.
Did you also remove the taller jounce on the rear axle?  If not I bet you bump stop is very close to the axle.
2019-chevrolet-silverado-1500-lt-trailboss-crew-cab-exterior-2018-detroit-auto-show-022-undercarriage-exhaust.jpg.985005ab8f74029961c2ab1e5cf5d613.jpg
Edited by pewterliftedz
Ya - this was removed as well.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,196 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
