I bought Eibach’s and I am very pleased.
Good to know. I'm assuming worlds difference over the stock ranchos on the z71?
I'd be in for a set if they can be used with the stock height/stance.  I've hit dips along the interstate (not even true potholes) that felt like I lost a kidney.  I understand stiff suspension for towing but the factory shocks are not absorbing much.  How difficult is it to do the fronts?
For the install? I would guess not horrible if you have some insight mechanically. That and renting a spray compressor. Dropping the lower control arm, sway bar endlinks and you should have enough room. At least from the looks of it when I did my level.
I bought all 4 shocks for $435 and my mechanic charged $200. I got tired of waiting on the 4600 as I never wanted the 5100. Bilstein told me the 4600 is the best shock for stock height and for towing. I set the Eibach’s on stock height and it worked out great. Same height as stock and I only have 1/4” rake on my truck. The Eibach’s killed the chevy hop in the rear end and the truck drives much more planted.
  • 1 month later...
16 hours ago, jbr1888 said:
Would these work? https://www.4wheelparts.com/p/bilstein-b8-5100-series-shock-absorber-33-253237/_/R-BBGL-33-253237
They are a hair shorter than the ones for the Trailboss. I have a 2 inch front level and a 1 inch rear lift block.
Not sure if this applies to your vehicle but I had my 2" rear blocks removed on my AT4 to get a more leveled look to avoid altering the front end.  After driving it around for a week I could definitely feel a difference in the way the rear end handled small and large bumps.  The smooth road handling had disappeared.  Since the stock OEM Rancho rear shocks were made for the 2" lift I looked for a non AT4/TrailBoss shock replacement with zero lift and went with the Bilstein 5100 which are good for 0-1" lift.  Truck now drives better than stock - on and off-road.  Very happy with the shock overall.
Where'd you buy them from??? Any wait time?
A local shop near me - SoCal Auto Style - ordered them and installed them.
On 1/10/2020 at 9:26 AM, vancealot29 said:
All,
I reached out to Bilstein for an updated date now that we are into the new year.  Their response.....
"We are estimating by the end of 2nd quarter"
And the wait continues........
Reached back out to Bilstein again this week.  Now looking at September/October per their rep.
Damn near two years in the new model......these things better wipe my ass after I install them ???
  • Haha 1
Damn....I'm trying to avoid dealing with the custom shops around here because the only one who would I don't trust sadly haha. I guess I'm waiting until they're officially released.
Damn near two years in the new model......these things better wipe my ass after I install them [emoji23][emoji23][emoji23]
Jeeez...I guess I'll buy them over the winter and install for spring time.
Ya - did not inquire about the front replacements.  The rears were in stock and installed next day.
Did you also remove the taller jounce on the rear axle?  If not I bet you bump stop is very close to the axle.
2019-chevrolet-silverado-1500-lt-trailboss-crew-cab-exterior-2018-detroit-auto-show-022-undercarriage-exhaust.jpg.985005ab8f74029961c2ab1e5cf5d613.jpg
Edited by pewterliftedz
Ya - this was removed as well.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 609 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
