3 hours ago, xPredator86x said:
Or what if....
The factory ran into a parts shortage on the AC Delco filters, and had to pull from another supplier temporarily to keep the line moving.
I was wondering that too but it seemed too suspicious. New air filter is in and truck is running smoother than ever.
Just changed mine at 45k miles and a tad over 3 years.  OEM filter still looked very serviceable..as in probably was good for another 45k.  Have noticed zero change in engine performance or mileage since the swap with the same AC Delco filter.
It's not going to run any different with a F-C filter in it; just because there's F-C filter in it doesn't mean it's not filtering (that's the company that own Ferrari and Alfa, I may actually prefer one of their filters over an AC Delco, just sayin).  The issue/question is why it's there in the first place... perhaps instead of pages of speculation you call the dealer and ask them why?
For me, the air filter is really important in the car because I often smoke cigarettes in the car and if the air filter is too weak the smell of the cigarette won't come out and also this smell can then imbibe in the chairs and the car will always smell, this is why I started to look for a new air filter in my car and reading the post on Damage Control of Orlando I found out about the ozone generators and I even bought me one I know that it's hard to use it and it has a lot of nuances but it's the best way to filter the air the car and I, but even with all these problems there is no better way how to clean the air in the car and I observed this after I had installed it in my car it doesn't smell anymore. What's your opinion?
Edited by AmeliaNorth
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
