Is there anyway someone can send me a duplicate of the aluminum piece they are placing inside I would GREATLY appreciate it! I act manufacture ABS Plastic Tailgate lettering for the 2019+ Silverado’s and would like to start making these colored “inserts” for the grills, so with your help I would laser cut a panel that fits into the same space over the mesh. Thanks!
I love the Chevrolet grill and this looks awesome. I wonder why the higher end trim levels like my LT Trail Boss didn't offer it? I just have a black bowtie.
On 9/28/2019 at 10:43 PM, Casey1234 said:
I did remove the entire grille. Takes less than 10 minutes to remove. It was a little tricky to remove the gloss black piece from the grille, just due to the number of clips.
I used the same paint as rowdydog, Rust-Oleum Cherry Gloss. I did not prime the aluminum flashing but I did de-grease and sand it so the paint would adhere properly. I cut the aluminum flashing down to 47" x 2 7/8" using tin snips. Seemed to be the perfect size.
Thank you for the dimensions, I wanted to get everything in place prior to removing the grill.
On 9/22/2019 at 11:41 AM, rowdydog said:
So I've seen guys wondering about adding color behind the chevrolet grill , I did this mod for mine, had a piece aluminum trim for house laying around, was already the right width, cut it to length painted it rustoleum cherry gloss paint snapped it back together and here it is feedback and ?'s  welcome.
Thanks you guys, I have painted my white accent piece and am waiting to get the dealership to install my fog lights on friday before I install.
Instead of painting and placing a thin piece of tin behind the letters has anybody just painted the mesh/slotted piece behind the letters?
I finally installed mine after being scared to remove the grill. Surprisingly it probably only took around 30 minutes to complete and I love the new look! Thanks to you guys for posting this!
This looks awesome!  Nice work.
@LimitlessParts have you been able to come up with any other solutions for this yet?
Thanks you Brewtus... sweet name BTW.. there is a post in this forum that states the exact measurements for the aluminum piece, I used those exact measurements...
Grill inserts finally came in! Letters came in multiple pieces (16 total). Everything fit well. These are thin metal inserts. Finish face came with a protective white layer that you need to peel off. Backside had the 3 mm adhesive tape. Clean off where the inserts are being placed, then use a heat gun to warm up the glue and remove the plastic film. With the proper amount of heat, the red tape will begin to peel up on its own. Once that layer is peeled, apply and hold pressure.
This is freshly installed and I have yet to put miles on it. We have had consistent 90° weather here in New Hampshire, so I’m interested to see how they hold up. I went black on black, so it’s subtle with the picture. To me, worth the $50. Enjoy
Edited by Craig N.
Such a great idea. Did my truck this weekend. I used the same paint mentioned above and aluminum flashing. Whole project cost $13 from Home Depot. I let the paint dry for 24 hours and then installed the flashing the next morning. It took about 30 min to install. Super easy.
Thank you! Thank you! For this idea! Completed and Love it! I did add rock guard clear tape for durability.
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
